humm?
1978 ,t/a 3660# 455 2010 / 1/8 7.86 1/4 12.40 @ 109,19 http://www.youtube.com/watch?v=6PaHbLnszS0 http://www.youtube.com/watch?v=XMxhM...eature=related 12.01@109 http://www.youtube.com/watch?v=MC-dganA2jQ 100 shot 11.78. A,ll new head cam combo 96 ported bye Mike Chell!! Comp cam yes the 284 XE. Firsthand outing of the street 7.69 1/8 12.15 109.47 hot and humid.not hooking. 1.73 60. |
As ted night said in caddy shack "we'll were waiting"
the suspense is killing me
i hope he is in the 11sss
1980 TA 455 th400 2.56 posi 12.27@111.48 http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
SORRY!
Sorry gentlemen! So much for throwin slicks on and runnin elevens! that frickin car of mine was all over the track! scared the crap outta me! 12.77 @113mph...1.99 60ft
434 CI TKO600RR 1969 Carousel Red RAII Heads...Pump gas 400+hp/450+tq at the wheels...life is good! |
What type of suspension?
May need to upgrade it 1st.
Leafspring
40yr old technology....some one said the left rear is loading when the right rear should be the side loading.
Someone else said the snubbers on the slapper bars are in the wrong location...therefore the suspension isnt loading right... Help me out here guys...i have always got good info from the board members here...not so sure I want to listen to all the strange theories I get at the track...you know ...the guy running a honda that wants to tell me what I should do ... Thanks in advance!~
Do the snubbers hit the spring or the spring eye?
Need to hit the spring eye to work correctly. Been years, but also remember thinking the R/R needs to be more close(if not touching) the spring eye.
Have any pics of the snubbers/suspension?
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
On the Bird we run the Competition Engineering traction bars; they are j-bolt style and longer than most but still had to add about 2" of metal at the front to place the snubber right under the spring eye. Actually replaced the snubber with a 1/2" diameter bolt that is threaded through the metal extension. That way we can adjust the clearance between the bolt and the spring eye very easily. Found that 1/4" on the left and 1/8" on the right worked the best for us. Having said that, it appears that you had more traction issues even with the new M/T's? Did you try different launch rpm's? or maybe the track was not prepped very well?
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
http://competitionengineering.com/articles/chassis.asp
http://www.baselinesuspensions.com/i...A_Drag_Car.htm
68 Firebird Are you running with the wind or breaking it? |
On slicks, too little tire pressure will cause the rear end to "float". Not enough burnout and they won't hook. |
tires
A friend tryed slicks but left the low profile wide radial tires on the front and almost took out both sides of the track. Either skinny radials or front skinnies to match the slicks. Not seeing what was happening thats my only thoughts. Rod
back in a few
Takin the Mrs. to dinner so gotta hurry....more to come later and thanks for the help...
Too little air pressure at first...15lbs...went to 23.5 and was much better as far as float . Still spinning in first and second... Burn out....kinda tuff with a stick and no line lock...just too dang excited to wait till i had both... come out of the box and blurp the throttle in second gear to get the burnout started...stab the brake...but not too much...its a bit to try and facilitate but i manage....5 to 8 second burnouts..not long enough but the damn thing wants to come around on me...lol..
makes sense...that what i am running....17'sx8 up front,street tires...and 15's with ET streets out back
Are you running at Sacto or Infineon? Wednesday night drags? I'm going to make it up there (Infineon) one of these days soon. Maybe us bay area guys should meet up there.
1967 GTO Tyrol Blue/Blk Cordova 400, TKO-600, 8.2 Posi w/3.55 400 + .020, decked to .005 SD Performance 240+CFM 670 heads RARE HO/RA manifolds RARE 2.5" Exhaust (18" Magnaflows) SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL) PRW stainless 1.52 roller rockers Forged TRW slugs SCAT H-Beam forged rods |
thanx!
#38
no
I had heard that very same thing from a local racer...i will make the adjustment
#39
68 Firebird, trying a q-jet now. 434/10.5:1/997's/240-242 HFT/4L80E/2800 Yank/3.42's/ Vintage Air/ 13.0 @105 mph 70 Lemans, 350/350, A/C, mostly stock 14 Ram CC, 5.7 Hemi, 8-speed, 3.92 lsd 97 Trans Am, HPP Aug 2012 http://www.highperformancepontiac.co...tiac_trans_am/ ***Sold*** |
#40
check it out bird freak, wednsday nights are the worst. my mustang bracket car runs in the mid 12s with a 1.7 60' time. At the e.t. races the car hooks up and goes straight. on a wednsday night at sac, the car is slip n slide down the entire track. every time. The mustang is stock suspension. maybe try a test n tune or e.t. race. oh, sorry guys for bringing a ford into the subject. wednsday nights=12.97-13.2. e.t. race=12.7s.
1968 pontiac lemans 400. 13.16@102/8.5:1 /6x-4/lunati bm 2 cam/ 3500 stall/3.55 gears. |
