Old 11-05-2022, 06:09 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default Anybody know what this is?
I pulled some heads off of a previously rebuilt 68 YD 400 and found this In a cooling hole. I’ve never run across something like it. And I don’t want to hear about the 8vr pistons. Thanks
ID:	601743   Click image for larger version
Old 11-05-2022, 06:39 PM
Formulas Formulas is offline
Did you see those piston's ? what to soon? That looks like an attempt at a home made restrictor or something there isnt anything i know of in the cooling system that could of migrated there.
Is there anything else squirrely going on with that engine tear down usually crazy things travel in multitudes
just one side ?
are the dowel pins in the block for the heads ? maybe a red neck work around for a lost pin
Old 11-05-2022, 06:53 PM
turbo69bird's Avatar
Maybe someone put bars leaks i there and it all accumulated like that??
And man your stocking up on Valve reliefs huh? Had to do it.
960 HP @ 11 psi, 9.70 at 146.
Old 11-05-2022, 07:08 PM
ponchjoe's Avatar
Lol, it is jus that one while and it seems like plastic. I dunno, just pulled it out, didn’t see anything weird. Any way to see block fill without taking the freeze plugs out?
QUOTE=Formulas;6384890]Did you see those piston's ? what to soon? That looks like an attempt at a home made restrictor or something there isnt anything i know of in the cooling system that could of migrated there.
just one side ?
.[/QUOTE]
