Old 11-05-2022, 12:43 PM
AllRise AllRise is offline
Default Name this hole…
Just got my block back from the machine shop, and noticed this threaded hole was wide open. Can someone help me name it, and what it’s purpose is? Thank you!
Old 11-05-2022, 12:47 PM
cnc's Avatar
cnc cnc is offline
Looks like clutch pivot ball stud would thread in there
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
The Following User Says Thank You to cnc For This Useful Post:
Old 11-05-2022, 12:56 PM
CNC is correct.
Old 11-05-2022, 06:59 PM
turbo69bird's Avatar
Wow I knew sticks were millennial anti theft devices but didn’t known we’d gotten so far down that line that people don’t recognize a clutch pivot threaded hole anymore nit picking on the OP just can’t believe it’s gotten this far along sign of the times .
960 HP @ 11 psi, 9.70 at 146.
Old 11-05-2022, 07:08 PM
Appreciate the help. Have only had experience with automatic Pontiacs I’m afraid, and just wanted to make sure I wasn’t supposed to plug that sucker up, like the reference photo.
Old 11-05-2022, 07:46 PM
Tom Vaught's Avatar
Boost Engineer
Some of us would be very happy that the block machining is still there for that clutch pivot ball stud.
Tom V.
