Old 11-01-2022, 10:36 AM
ta man ta man is offline
Originally Posted by Gach View Post
The old rule of thumb, for your power level for every 100# lost , is worth a tenth. So 64 lbs is roughly 1/2 tenth. When your up in 800 hp range 200 lbs is worth a tenth. 2 point more compression is worth 20 hp, sometimes a little more. Not that you would want to go there. Nice to see that’s your best ET to date. Congrats hard work and $ spent paid off.
Thanks, more time in the garage and on the track helps. I do have some good friends in the hobby that we discuss our builds amongst ourselves. Usually coming up with some good ideas ( not always) that help performance.
  #222
Old 11-07-2022, 10:08 PM
vicgto vicgto is offline
Originally Posted by ta man View Post
New bests 10.688/127.35 followed up 15 mins later before track closed with a 10.679/127.5. Had to leave relatively soft all day my 60 foots were 1.52 and 1.53 on those runs. Had a late start to the day..and track issues plus blew the tires off first run..didn't look good until I ran a 10.78 leaving easy at 127..I knew there was some et coming.
Great day overall, went over to check out a 71 GTO turns out it was a 290 cfm SD KRE headed 455 with an OF cam and a " Jim Hand" Continental Convertor! Word gets around I guess!
Hi Ernie, It was a great day, my car is actually a 72 GTO. It was nice meeting you last Saturday. I haven't spent much time on the Pontiac forums in the last few years but when I did it was on mainly on Pontiac Zone (although I made a few posts on PY Online). After we spoke I checked out some of your posts and I can't stop reading, very good info. Thank you for your sharing, hope to see you again next year.
1972 GTO
468 2 Bolt Main w/Eagle rotating assy
SD Ported 295 KRE D Ports 10.8 CR
OF Hydraulic roller w/ 1.65 stainless rockers
Performer RPM Intake
Holley 3310 780 Vacuum Secondary
TH400 with 10" Continental Convertor
8.2 BOP 4 pinion 10 Bolt with 3.36 gears
11.428/118.95/1.618
  #223
Old 11-08-2022, 12:32 AM
Sorry, once I see the KRE heads I don't see much else.
Many good guys on here with 100 times my experience. You will find many good answers from members ( and the occasional spat for comedy).
Great meeting you as well.
  #224
Old 11-08-2022, 01:32 AM
slowbird's Avatar
slowbird slowbird is offline
I'm curious what your 1/8 et/mph is if you're willing to share.
  #225
Old 11-08-2022, 11:37 AM
Here are the two best slips, fifteen minutes apart. Also added is a slip from May 1 with almost identical Air Density..with the UCC convertor which was too loose.
Name:	new best 2022.jpg
ID:	601872   Click image for larger version
Name:	cayuga spring.jpg
  #226
Old 11-08-2022, 02:17 PM
7.269 at 94.72 MPH
1972 GTO
11.428/118.95/1.618
