Old 02-04-2014, 10:56 AM
stone7777's Avatar
stone7777 stone7777 is offline
Default Help identify wiring harness for 67'
My car came with two interior wiring harness's. 1967 GTO Auto with Air
I can not find a difference.
Also, I can not find any type of date code.
Can someone help me figure out the year or guide me on what to look for.
I am having trouble uploading the photo's.
Thanks Chris
Old 02-04-2014, 12:48 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Was your car originally an A/c car? If so you have a "with air" harness
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 02-04-2014, 02:43 PM
Andre's Avatar
Andre Andre is offline
The "air" harness is a plug in to the main harness and is identifiable by brown wire with red plug.
An easy way to figure out your harness is to lay it on the table as if it were on the firewall, and see where rthe wires route to. The blower harness will be towards the right. Other wires in that direction will be door jamb switch- white, and glovebox switch- orange.
Old 02-04-2014, 03:49 PM
stone7777's Avatar
Pictures of one of my harnesses
Any help?
ID:	351795   Click image for larger version
ID:	351796   Click image for larger version
Old 02-04-2014, 03:55 PM
stone7777's Avatar
one more of the inside
Old 02-04-2014, 04:10 PM
Andre's Avatar
Is that harness from a convertible? I see the heavy purple and grey wires (at least I think I see that) that run to the convertible top motor.
Old 02-04-2014, 04:23 PM
stone7777's Avatar
These two pictures are of my other wiring harness.
This harness or the other A/C friendly?
ID:	351800   Click image for larger version
Old 02-04-2014, 04:25 PM
stone7777's Avatar
I have no clue
I am in well over my head here.
Old 02-04-2014, 05:16 PM
Old Goat 67's Avatar
That fuseholder in post 4 is not from a 67.
Old 02-04-2014, 08:33 PM
1966geeto 1966geeto is offline
Agreed not a 66 or 67 fuse box ?
Old 02-04-2014, 08:49 PM
stone7777's Avatar
OK
Stupid question
Will it still work?
The ignition is still in the dash.
Old 02-04-2014, 09:02 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I have a brand new 67 auto with A/C harness out in my shop.I'll take some pictures of it tomorrow if that will help. I think the fuse block shown in your last photos may be correct but it looks really corroded.
Old 02-04-2014, 09:18 PM
stone7777's Avatar
I would appreciate that.
Old 02-04-2014, 09:26 PM
fyrffytr1's Avatar
OK, You talked me into it so I went out to the shop and got my new harness. as far as the A/C part, it doesn't affect the dash harness as the A/C harnesses are separate and plug into the dash harness.
So, here are some pics of my 67 Dash harness for the console shift, auto trans and gauges.
Name:	Dash Harness 001.jpg
ID:	351857   Click image for larger version
Name:	Dash Harness 002.jpg
ID:	351858   Click image for larger version
Name:	Dash Harness 003.jpg
ID:	351859   Click image for larger version
Name:	Dash Harness 004.jpg
Old 02-04-2014, 09:29 PM
fyrffytr1's Avatar
And three more.
Name:	Dash Harness 005.jpg
ID:	351861   Click image for larger version
Name:	Dash Harness 006.jpg
ID:	351862   Click image for larger version
Name:	Dash Harness 007.jpg
Old 02-04-2014, 09:36 PM
fyrffytr1's Avatar
Andre,
I may be wrong but I think the convertible top wiring is separate from the dash harness. The heavy purple and gray wires are added to the outside of the ribbon harness and the power comes from a wire included with the convertible top switch. At least that is the way it was with my 67 vert.
Old 02-04-2014, 09:41 PM
stone7777's Avatar
A big help thanks for taking the time.
Old 02-04-2014, 10:27 PM
Andre's Avatar
Fyrfftytr1 I agree with you about the convertible top wires, but I don't know what else those 2 wires could before.
Stone7777 I checked my harness collection and found I have a nice one for 67 with the add on a/c harness if the ones you have don't work
The Following User Says Thank You to Andre For This Useful Post:
Old 02-05-2014, 08:15 AM
Originally Posted by stone7777 View Post
OK
Stupid question
Will it still work?
Not enough circuits pretty sure mine has 11 or 12 fuses with a couple of acc plug ins have to look.You can make anything work just wont have enough to protect all the circuit's properly.
