Old 08-20-2020, 01:03 PM
Jack P. Jack P. is offline
Default Quick ratio steering
I am looking for options to convert my loose 4 turns LTL power steering box on my 65 GTO. Are there any lower cost options out there. I see new boxes for $500+ but would like something less if I can. Does the Monte Carlo SS from the 80's fit other than a new rag joint and fitting inserts. All boxes have stops built in, and in different places. Camaro and Firebird boxes I think fit but have stops preventing it from working on a A body. I am looking for 12.7 to 1 ratio. Some sellers advertise LTL but depending where the stops are that number don't help. Any options appreciated.
Old 08-20-2020, 01:17 PM
Cardo's Avatar
Cardo Cardo is online now
I had Carhex do mine a few years ago. Converted my box and sent it back in 6 days .... although i did glass bead mine before i sent it to him and requested the he not paint it. Back then he was charging $180. Get his phone number off of this link and call him to see what he is charging these days. I initally found him though ebay, but his listing right now is showing $599 due to a lack of cores. I will say it works well, 3 turns LTL, no leaks, and i got my original box back. https://www.facebook.com/carhex1/
Old 08-20-2020, 10:46 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
I had a box out of a 76 Trans Am and it had the same stops. Use your original pitman arm an 85 Chevy 1/2 ton rag joint.
Old 08-21-2020, 01:47 PM
vertigto's Avatar
vertigto vertigto is offline
Asked the same thing recently...
https://forums.maxperformanceinc.com...d.php?t=842486
Old 08-21-2020, 04:33 PM
Some good reading. Still a bit confusing, I can deal with a new rag joint and fittings in the lines but want a box that bolts in, has 12.7-1 and has no stops or stops in the correct place for an A body. So what kit did you order from Jegs?
Old 08-21-2020, 04:49 PM
vertigto's Avatar
Borgeson, here is their site...
https://www.borgeson.com/xcart/produ...productid=1792
This is the deal from Jegs...
https://www.jegs.com/i/Borgeson/153/800130/10002/-1
But more info on Summit's site (see reviews/Q&A)...
https://www.summitracing.com/parts/brg-800130
Also Ridetech seems to really like it. Do a search on their site or on protouring.com...hope it helps you make a decision.
Old 08-22-2020, 05:09 AM
Geoff Geoff is offline
Order from our host & you will get the correct box.
Old 10-08-2020, 11:40 AM
footjoy's Avatar
footjoy footjoy is offline
I am using a 95 Jeep GC box bolted in works great need to get Lee fitting adapters and new rag joint. It is a saginaw box
Greg
Old 10-08-2020, 04:17 PM
ZeGermanHam's Avatar
Another Jeep GC box user here. It's the most inexpensive way to get quicker steering on an A-body.
1998 BMW 328is (track rat)
Old 10-08-2020, 07:00 PM
The Champ's Avatar
I bought a Lares 10:1 box and a new Lares power steering pump from Rock Auto. Manufactured in MN. Would have like to have just ordered direct, but it was much cheaper to go through Rock Auto (they actually told me to go there).
Total cost was $500 for both and that included a $75.00 core charge for the box which I got back.
Old 10-09-2020, 01:36 PM
Do you have part numbers for your order. I would like to look at that.
Old 10-09-2020, 04:21 PM
The Champ's Avatar
Jack
Here are the part #'s I ordered and the links to info on the Lares website:
LARES 12034 (New) With Reservoir
https://catalog.larescorp.com/part/12034/
LARES 972 (Remanufactured) Remanufactured; 4 Bolt Housing
Power Gear; OE Design; 10:1 Fast Ratio; Direct Bolt In
https://catalog.larescorp.com/part/972/
Old 12-07-2022, 12:46 PM
grivera's Avatar
grivera grivera is online now
Thread revival time! How do you like the 10:1 box? Do you do autocross?
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 12-08-2022, 08:43 AM
The Champ's Avatar
I like the box, but don't autocross. Just like driving windy twisty roads....
Old 12-08-2022, 04:46 PM
About 20 years ago I had Tom Lee in California build me one of his steering boxes.
Very, very nice P/s Box and well worth the money he charged at the time.
https://leepowersteering.com/
Phone: 661-568-9170 or Fax: 661-885-8185
He had built boxes for all of the big name racers.
Old 12-08-2022, 11:39 PM
OG68 OG68 is offline
X 2 with Lee Steering. They've rebuilt and upgraded three boxes for me over the years. Excellent work and great communication during the process.
2007 Cadillac SRX
Old 12-09-2022, 10:00 PM
lust4speed's Avatar
Tom retired in 2015 but Allan Padelford continues with the business and have heard nothing but good about their continuing service.
When I needed a power steering box for the Catalina wagon a couple years ago I called them but at that time they were too far out for me. I ended up going with a new 10:1 Lares box from Rock Auto that had the best price. I never noticed the somewhat quicker 12:1 steering box I put in the GTO probably because it was so close to the ratio in the daily driver. I do notice the really quick box in the wagon but like it.
Mick Batson
Old 12-10-2022, 02:44 PM
Dick Boneske's Avatar
I bought a box from Advance Auto Parts for a Z28 Camaro. Ratio is great, pipe sizes are the same as OEM, but the stops have limited my turning radius. I wish I had the old box back.
BONESTOCK GOATS
'99 Bonneville SE Sedan
