Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-31-2018, 12:18 AM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
Default Rebuilt 400
I am redoing my 1971 Trans Am & selling off several items. Engine for sale will be a running pull out so comes 100% complete from carb to pan with the following specs:
Rebuilt Qjet carb
Edelbrock Performer aluminum intake on it now (for the 71 look) but I have a stock steel 1970 intake if you want that for an extra $100
5C-7 heads - 2.11/1.66 valves 100cc milled .010" to remain flat & bump CR to ~8.3 with the thin head gaskets. You could easily mill it to bump CR higher but I decided to keep it super pump gas friendly down here for the FL heat. (take another .020" off so .030" in total = a very nice 8.75+ CR for a nice hp bump or you mill them & the intake more to get up to 9.0+ CR for additional performance!) This was built as is to be safe & reliable off any pump gas & octane!
Comp Cams 1.5 ratio SS magnum roller rockers
Comp Cams Valve springs to match cam specs
Comp Cams pushrods
Comp Cams custom grind cam: duration @ .050 is 228/231 .474"/.480" lift 114+6 LSA (I have the cam card still.
Block is a low mile 197X 400, (dont remember off hand the year but will update ad), it is the thick web version & completely deburred.
Bore was perfect & needed nothing but a light hone.
Stock Pontiac rods
Cast Pistons
ARP rod & main bolts
Stock Pontiac steel crank
Neoprene rear main seal - NOT THE ROPE CRAP THAT LEAKS!!!
New Bearings are all Clevite 77
New Colyes timing chain
New RAIV oil pump
New stock valley pan, windage tray & oil pan
HEI distributor
Headman Fbody Headers
High torque mini starter
Videos of it running are here:
https://youtu.be/kFE_yoqn5jE
https://youtu.be/TX3MLjBZiJU
Estimated upper three hundred horsepower area (365hp - 375ish) & over four hundred torque (405tq - 410ish). It was not built as a race engine or high hp / radical cam / no vacuum / undrivable monster. It was built to be a solid, SAFE, street engine good for cruising or the occasional 1/4 mile blast. We have put about 1500 miles on it & she runs like a champ. It blows the tires off in 1st, spins it in 2nd & chirps them in 3rd all with a 3.08 rear too!
I will sell it for $2750 OBO complete & shipped to any Fastenal store in the US. Depending on pallet / shipping situation I may just include the engine stand it will be moved with. If you are local to the Tampa FL area or can arrange pickup & have cash I will work with you on the price. You can still have the engine stand too :-) If you know what it cost to build a high performance Pontiac V8 I think you will find value in this engine combo.
Additional parts for sale off my TA will be the tranny, interior, Hotchkis suspension, global west control arms & honeycomb wheels with tires.
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
Old 12-31-2018, 12:36 AM
cdoggy81's Avatar
Photos:
ID:	501403   Click image for larger version
Old 12-31-2018, 09:52 AM
chiefbigb chiefbigb is offline
PM sent
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 12-31-2018, 02:05 PM
427454 427454 is offline
pm sent
Old 01-01-2019, 12:42 AM
cdoggy81's Avatar
PM’s have been replied to. Thanks
Old 01-04-2019, 12:08 AM
cdoggy81's Avatar
SOLD!
Thank you ;]
Old 09-04-2019, 09:38 AM
panhead59 panhead59 is offline
Default Engine wanted
Did you ever sell this engine ?
Old 09-04-2019, 09:39 AM
Default Got it. This site is lousy. Hard to navigate.
Ok.
