Did you happen to use the under dash ignition jumper harness on your RAV Judge? If not that might be the problem with your 406 coil not working. As I understand, it was used to give a full 12 volts to the coil. Just a thought.
Yes the jumper plug is there. Thanks
Very cool engine . Nice to see it all together .the little details are always tough, impressed.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
Current pic with manifolds
The Following User Says Thank You to Aluminum Chief For This Useful Post: | ||
Drool....
Very cool! |
A body manifolds or F body?
Really loving those manifolds !!!!
Gen 1 short decks.Tom
They made 25 sets,they should be EZ to find!There is a set about 40 miles from me!Tom
the drivers side, yeah. the pass side, eeh, not so much (jmo) to clear the block mounted oil filter, it looks like a regular log.
“We don’t build a ‘luxury’ car. We build a performance car then we make it luxurious.” |
Anybody dropped compression for pump gas on the V curious how much it affects them
Especially bottom end?
All my engines are 9.5.Tom
I'm late to the party, but WOW, that is awesome, Ken!
On the epoxy coil, there were other applications for those - I think they used them on one of the OHC-6 installations - F-body? I have no references for which part numbers though. I had a #240 red CD coil that I had planned to use on my V. Most of the magazine articles showed the epoxy coil (not all), but the '70 A-body service manual diagram shows a conventional coil with the CD amplifier, so I wasn't going to lose any sleep using it. Like has already been said, the #406 is unobtainable, and I sure couldn't have afforded it if I had found one. I am looking to use the D-R CD Ignition on my '63 Tempest build. I have a distributor, but need an amplifier and coil. If anyone has a lead, please let me know. A non-functioning box would be fine as would an Olds UHV version. I have rebuilt two of them with good results.
Hoping to finish a project while I'm still able to push the clutch in.... 1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures |
It's also why you can't trigger a tachometer from the coil. The amplifier box provided a low voltage pulse signal for a tach.
Chevrolet also used one of the epoxy fillled coils in the late 50's and early 60's on their 6 cylinder. It is # 296 and was only 9 volts. |
Looks very cool!!
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
Just a side note but with solid state ignitions beginning with the 1962 Delcotronic, GM always used a transistor circuit while the points ignitions recived a passive circuit.
Is easy to convert, just depends on which tach it has. |
