Old 02-20-2014, 07:45 PM
grivera's Avatar
grivera grivera is online now
Default is this a good deal on Cal Custom valve covers?
$77 shipped to me? Seller says no signs of cracks or damage...Also, can anyone tell by the part # 40-2200 if they fit Pont V-8?
ID:	353776   Click image for larger version
ID:	353777   Click image for larger version
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 02-20-2014, 08:23 PM
huddie huddie is offline
Not a bad deal if they will polish up.Yes,they will fit Pontiac.
Old 02-20-2014, 08:44 PM
grivera's Avatar
Is there any way to tell if they'll polish up without handling them?
Will Rivera
77 TRASHCAN's Avatar
I like those...everything these days seems to be priced too high..if my paycheck would just adjust at the same rate.........
What does $77.00 buy these days...not much
They look like they can be polished. They look smooth, and not pitted, I believe they'd work for you...
Shut it off
Shut it off
Old 02-20-2014, 09:22 PM
David Jones's Avatar
You'll be sanding a bit anyway so there isn't much you can't deal with.
Old 02-20-2014, 10:05 PM
grivera's Avatar
Dave, I thought I had seen thread you created when you restored your valve covers but can't find it...
Will Rivera
Old 02-21-2014, 08:56 AM
moneypit's Avatar
moneypit moneypit is offline
Cool
X 2, The old Cal Customs come with a "cool" factor built in!
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
77 Grand Prix base model, 350 pontiac
97 F250 7.3 turbo diesel
85 CJ7 Laredo
65 Impala SS 396, 4 spd, A/C.
Old 02-21-2014, 11:23 AM
Good deal if they're Pontiac V8 Cal Customs. Won't sell the pair of Pontiac Cal Customs I have for that. I can ck on the casting numbers early in the AM.
On an engine build that uses roller rockers, one can get away with using the mid 60's-80's small block Chevy Cal Customs along with running Pontiac valve covers spacers that have been tweaked to accept the Chevy bolt pattern.
Old 02-21-2014, 12:24 PM
The search for info.....
http://forums.maxperformanceinc.com/...ght=cal+custom
More info.....post 18, the basics......
The pic is AFTER an initial clean-up. The one in back had been polished on a little. I discovered that any areas not bright shiny aluminum had to be sanded with various grits of paper BEFORE they could be polished effectively...to remove oxidation (?). Mine have looked great for years with no additional polishing or painting. I did hit them with some Mothers last year before I put them on my 455 but honestly they looked great anyway. I did not clear coat them.
Old 02-21-2014, 02:28 PM
geeteeohguy's Avatar
I have a set of those in near mint shape that came on a car I bought over 30 years ago. Agreed you got a good deal. I sure wouldn't sell mine for $77. My favorite aftermarket valve cover, in looks and quality.
Jeff
Old 02-21-2014, 09:23 PM
grivera's Avatar
I haven't scored them yet- waiting on reply from seller
Will Rivera
Old 02-21-2014, 09:53 PM
You'll never have a leaky valve cover gasket again. Those Cal Custom's are straight and stiff. I run the rubber Felpro's and reuse them over and over and over.
Old 02-21-2014, 10:06 PM
grivera's Avatar
Those look great! Did you use a buffer?
Will Rivera
Old 02-21-2014, 11:40 PM
MNBob MNBob is offline
X2, I have the exact same combo.
1979 TATA Extreme TKO .64
Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry
Old 02-21-2014, 11:42 PM
After sanding I used a buffing pad with rouge that I mounted on my trusty Black and Decker bench grinder. I also have a flex shaft motor I used with a small buffer wheel.
Looking at your picture you will need to start with sanding.
