Old 08-10-2013, 10:20 AM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
Default Need help snow plow for 2013 GMC
I'm thinking of not putting a plow on my 2013 GMC for a variety of reasons, the main one being appearance of the truck side attachment. On my 2011 Chev I had to cut the valance to mount the Fisher MM2 plow. IT looks like I would have to do that again to mount my existing plow.
Does anyone have pics of a decent plow mount on a new truck that doesn't involve cutting the valance?
Anyone want a MM2 plow setup for 2011-2013 CHev/gmc?
Old 08-10-2013, 11:25 AM
Check out the boss units. a Local guy has one on his truck and the valance isn't cut that I remember seeing. If it is it's not obvious.
Mike
former." --Albert Einstein
- Winston Churchill
Old 08-10-2013, 02:35 PM
http://www.autoaccessoriesgarage.com...ws/_GMC-Canyon
Some under the bumper mounts here.
Not going to snow this year.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 08-10-2013, 03:02 PM
74gto's Avatar
74gto 74gto is offline
Keith,
Like Mike said, check out Boss. Every Western, Fisher, Blizzard, and Airflow I put on a Chevy had to get the front facia cut or notched. The only one I can't remember for sure is Meyer. May not have to with the new Meyer mounts. Did you get a later model 2013 where they finally put a bigger front axle weight rating on the truck?? They carry the plows much better, don't have to crank the torsion bars up very much. If you're gonna get a new plow, check out a very productive one. Blizzard Speedwing!
www.blizzardplows.com. I sold a lot of those last year, and the guys loved them.
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
Old 08-10-2013, 10:30 PM
sonjaab's Avatar
sonjaab sonjaab is offline
Are you talking a 1500 1/2 ton GM truck?
The 1/2 ton gmt-900s have a thin "air d*m" /deflector that runs across the front
under the rad support that gets cut. The 2500/3500 do not have it.
A newer Western/Fisher plow should not require air d*m cutting for a gmt-900 2500/3500
anyway. Unless your using the older style mounting carton................
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala,
94 Buick, 77 Triumph Bonneville
Old 08-11-2013, 01:12 AM
2500 HD
Old plow is Minute MOunt 2, so cut is necessary. Two pushplates in place of the frame hooks
Boss runs quite a low mount
New truck is 2500 HD with diesel, but is 10000 gvt. Chev was a 9600 or something like that. Both were plow prep from factory, so had quite large front axles. Earlier than 2011, no plows for duramax.
The more I think about this I just would rather get a winter beater with a plow on it.
Old 08-12-2013, 08:41 AM
Deadhead's Avatar
Deadhead Deadhead is offline
One word Keith:
Tractor.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
Old 08-12-2013, 09:10 AM
sonjaab's Avatar
NO VYU plow prep on 2500/3500 gmt-900 diesel x-cab or crews.
VYU plow prep on reg cab 2500/3500 gmt-900 diesels only.
new Boss plows require bumper cover notching/cutting.
My bud at the hardware store has a 2013 with a Boss 8 footer
and they carved it up pretty good!
NEW western, fisher and blizzard use the same mounting system
and require no cutting (on a gmt-900 2500/3500)
will dig out camera and take pics................
Why guess?
Take a trip over to www.letstalksnow.com/forums
Those guys know their stuff and can answer all your questions and have pics............
Old 08-12-2013, 09:21 AM
sonjaab's Avatar
Heres a 2012 valance removed so no cutting necessary.
Old 08-12-2013, 09:30 AM
bankbook's Avatar
bankbook bankbook is offline
My 2010 has Western Ultra Mount. No cutting necessary. When the lock hook is engaged it will hit the lower valance slightly. No damage occurs at all over the last three years. If concerned, just put a piece of flooring rubber as a protector when engaged.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 08-12-2013, 01:33 PM
74gto's Avatar
Why guess?
On the Blizzard PH2 the cross beam will inerfere with the plastic underneath the towhooks. You can't get it on without notching plastic. Says right in Power Match system bumper notching required.
Same kinda problem with the Western recievers. The pin that goes through the receivers hits the plastic. Gotta notch bottom of plastic under towhook.
74 GTO 406 T400
Old 08-12-2013, 09:13 PM
sonjaab's Avatar
I have a Western rig on my 07 gmt-900 2500
No notching/cutting required, pin clearance is fine.
74........ Ever heard of Jerres Service in Erie Pa?
Hes the Blizzard god ! Been there many times and watched lots
of installs! Danger wings and the Erie special plows................
Check them out http://www.jerres.com
Old 08-13-2013, 12:04 AM
Stuckinda60s Stuckinda60s is offline
Originally Posted by Keith Vrabec View Post
2500 HD
Man, you just missed a real good deal on a Dodge Ram with a plow on it.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
