Cam selection based on availability
Starting a new post since a lot changed since I started this one last year.
https://forums.maxperformanceinc.com...d.php?t=843418 Need cam advice based on actual availability due to current cam shortage from lack of cores. Have: 70 GTO 5 speed 400 block 4.25" stroke Eagle crank #12 heads reworked by Butler with Crower 68404 springs and 7/16 studs. All new Ferrea valves, etc. 72 cc Plan to have block done 0.035 over with Icon forged 30 cc dished pistons. ~9.5:1 compression. Forged rods will also be purchased. The heads limit power as they are unported, but that is OK. They are original and I plan to keep them as is. The springs limit lift to 0.520. Budget calls for HFT. Looking at what's out there in stock, there is the Melling SPC-8 041 Ram Air IV clone that I could use with 1.65 rockers but will I need to elongate pushrod holes? The Lunati 704 has a little more than 0.520 lift and probably wants a little more spring pressure than the 68404 springs provide to control its aggressive ramps. I am willing to sacrifice a little power for reliability/not modifying the heads further. Would you do either one of the above or wait on another cam option in 6 months or more?
1970 GTO 400 Atoll Blue, PS, PDB, A/C Was M20 4 speed, now has Keisler RS600 5 speed. |
