Old 06-24-2021, 04:46 PM
My 4-speed 400 (standard 330 hp) Firebird had factory A/C with a 3.23 open rear.
Moved out pretty well with the 2.52 first gear, with a 2.64 it would have been great.
Old 06-24-2021, 05:31 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
3.08 with a 2.64 low 1st is about the same gearing as a 3.23 with a 2.52 1st. A lighter car but similar power, had a 68 AMC AMX 390 with a 3.15 rear and 2.20 low and it was not a fun car in stop and go driving. Changed to a 2.64 low T10 and it was night and day different. Could roll out from a dead stop in 1st with very little throttle.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 06-24-2021, 07:37 PM
Tom Vaught's Avatar
Boost Engineer
IMAGINE A 5 SPEED TRANS WITH A FIRST GEAR OF 3.27 AND A FINAL GEAR OF 1 TO ONE (with all of the gear splits (rpm drops) being the same.
I run a 3.27 trans and a 2.75 Ford rear gear and have the best of both worlds.
There are combinations like that with some aftermarket trans but the basic
Muncie 4 speed with a 2.20 1st gear is a poor choice for most applications, even with a 455 engine.
Tom V.
Old 06-24-2021, 07:49 PM
Gary H's Avatar
Gary H Gary H is offline
As far as I can determine; numerically, the lowest gear ratio you can buy new for a 8.2 BOP is a 3:36. I think it is only made by Yukon. If you want a 3:23, 3:08 or 2 series gear ratio it will have to be used.
Old 06-24-2021, 08:44 PM
dmac dmac is offline
Going from a 26" tall tire to a 28" tire changes gear ratio from 3.55 to 3.30 according to Wallace racing Chart. Going from a 3.55 to a 3.36 AND getting slightly taller tires could get you pretty close to where you want to be.
Unless the car runs quiet, I hate highway driving at anything above the lowest rpm possible. Aiming for 2000-2400 rpm at between 50-60 mph is kind of a middle point if driving is split much between city and open freeway. And getting a little above 2500 rpm should get you close to max toque production, so passing/acceleration should still be decent
Old 06-24-2021, 11:25 PM
The Champ's Avatar
Lee
I have a '64 GTO with it's original M20 with 2.56 1st gear and switched from 3.42 rear gear to a 3.08. My rear tires are 26.7" tall.
2.56x3.08=7.88 effective first gear.
I made this swap to reduce the RPM's on the Interstate, with the caveat that if I didn't like the result, I'd buy and M22Z with a 2.98 first gear. That was 3 years ago and I'm still running my original Muncie.
I'm 1.5 - 2 hours south of you if you or your friend wanted to drive my car.
I have to admit, I have been giving some thought to the direct fit TKX 5 spd which has either a 3.27 or 2.87 1st gear and either a .68, .72 or .81 OD depending on 1st gear ratio.
Old 06-24-2021, 11:28 PM
leeklm's Avatar
leeklm leeklm is offline
I was thinking the 3.08 gears were readily available for the 8.2 BOP, but after another quick search, you seem to be correct!
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 06-24-2021, 11:35 PM
The Champ's Avatar
Just did some checking based on the fact that you say he can currently start in 2nd gear.
This is what I found for the 2.64 1st gear T10:
Borg‑Warner T‑10 2nd Design 2.64 1.61 1.23 1.00
With a 1.61 2nd gear and a 3.55 rear - the effective ratio is currently 5.72
Old 06-24-2021, 11:44 PM
leeklm's Avatar
Borg‑Warner T‑10 2nd Design2.641.611.231.00
1.61 is the 3rd gear ratio. 2nd gear is a 2.1 ratio
Old 06-25-2021, 12:31 AM
77 TRASHCAN's Avatar
Exactly how much highway cruising, does your friend intend to do?
Shut it off
Shut it off
Old 06-25-2021, 07:02 AM
The Champ's Avatar
2.1 apparently is the 2nd gear ratio for the Super T10 built from 1977 - 79
https://itstillruns.com/super-t10-tr...s-7713046.html
I was looking at the gear ratios for a 2nd gen T10:
https://m.roadkillcustoms.com/transm...r-ratio-chart/
If in fact, your friend has a Super T10 with the 2.1 2nd gear, the effective gear ratio with a 3.55 is still only 7.45 vs the 3.08 rear with the car in first gear of 8.13.
A '64 GTO with a 3.23 rear gear and the original M20 with a 2.56 1st gear (mine originally had 3.23 rear gears before I put in the 12 bolt with 3.42's) was 8.27 - very close to the 8.13 with a 3.08 rear and your friends existing transmission.
That 3.23 with an M20 was probably the most common setup from the factory back in the day as it was the standard rear gear when you ordered a wide ratio 4 spd.
Over the nearly 30 years I've owned this car, I've gone from a 3.23 non posi rear until I found a 3.36 posi which ultimately failed, to a 3.42 12 bolt and now am running 3.08's in the same 12 bolt.
Old 06-25-2021, 08:00 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Leave rear alone and maybe invest in a muscle car 5 speed swap with OD later
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
Old 06-25-2021, 08:37 AM
leeklm's Avatar
Correct on the Super T10- this trans is a 1979 ST10. Btw, thanks for the offer on the test drive- I am up near Rogers , so be sure to look me up if you make it out this way for a car show, etc.
I was hoping to hit the "easy button" on this, but considering the limited options on gears for the 8.2, probably just leave it alone for now, or a swap to 3.36 and maybe taller tires at some point- or as mentioned, look at an OD trans if he tends to keep the car long term.
Thank you for the replies- good discussion!
Old 06-25-2021, 09:38 AM
Formulajones's Avatar
This^^^^^
Given the fact that this is a classic car and we all know most people don't drive the darn things more than 2000 miles a year anyway, I'd just leave the 3.55's in it and enjoy it. Not worth the hassle of swapping gears, then living with a subpar 1st gear effective ratio around town, just because he might see the highway once in a while.
Besides, 3.55's just aren't that bad on the highway. Our daily driver for years had 3.55's with a 27" tire and it cruised at 65 all day long at 2900 rpm and got 17 mpg doing it.
Then later, if he really decides to actually drive the car more, longer distances etc.....just put an overdrive in it and be done with it.
https://youtu.be/XqEydRRRwqE
Old 06-25-2021, 10:54 AM
69 Limelight 69 Limelight is offline
Default Thoughts on 3.55 to 3.08 gear swap
FYI, there's a set of used 3.23 , 8.2 gears for sale in the "Performance Parts For Sale/Wanted" section. There's pictures but, I'm no "gear man" and don't know if they look any good or not. No gear experts on this forum have chimed in and given their opinion of quality. As far as thoughts, I'm with Formulajones and one or two others. If only going to drive a few thousand miles a year leave it alone. If you're going to use it as a cross country cruiser go straight for an overdrive. Everything else is just a "bandaid" and with an overdrive you get the best of both worlds. Starting gear multiplication and low RPM cruising. When you drop it in OD it becomes a complete different car. Ask me how I know.
The Following User Says Thank You to 69 Limelight For This Useful Post:
Old 06-25-2021, 11:30 AM
More highway go 3.08, that 2.64 low gear is a game changer. Same 8.13 ratio as the M20 paired with a 3.23.
More city go 3.23.
Old 06-25-2021, 11:43 AM
Also gear changes of only a quarter rotation are barely even noticeable hence not worth it. 3.23 sucks almost just as bad as 3.55's at 70 mph Thats why I usually recommend 3.08 on automatic folks with 2.56's , to me the minimum of a gear change is a half rotation to b worth it or noticeable regardless
  #38
Old 06-25-2021, 01:38 PM
I've been saying this forever, and people really don't grasp it until they actually perform the swap to the overdrive. Then usually the next comment I hear is "wish I'd have done that sooner" lol
  #39
Old 06-25-2021, 04:37 PM
Tom Vaught's Avatar
Boost Engineer
There were weak GM 3 speed overdrive transmissions (Saginaw) and there were weaker 3 speed GM over drive transmissions (Muncie), and there were STRONG overdrive FORD transmissions. These transmissions were actually the cast iron 4 speed "Top Loader" transmissions but Ford Engineering made the trans with 3 normal gears 1,2, and 3 AND changed 3rd gear to 1 to 1 and 4th gear to overdrive.
If I ever had to have a "highway cruiser" early GM body 64-72 GTO, etc) I would find a Ford 3 speed overdrive trans and bell-housing with the dual pattern (1965) trans mount and run that trans with a Ford clutch plate. Food for thought.
Much stronger than some modern overdrive transmissions.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
  #40
Old 06-26-2021, 11:34 AM
punchyponcho punchyponcho is offline
Hell, you could run a 2.56 or a 2.41 rear with a 3.42 ST10. That’s what I have in my Grand Prix.
