Pontiac - Street No question too basic here! |
View Poll Results: If you've installed CVF brackets on a Pontiac, did you have to modify them? | |||
Yes. I had to modify the CVF brackets to get the correct pulley alignment. | 4 | 22.22% | |
No. The CVF brackets/pulleys were aligned correctly out of the box. | 14 | 77.78% | |
Voters: 18. You may not vote on this poll |
Put the same setup on my wife's 71 T/A. Tall valve covers and A/C. Had to do some widdling on spacers and fabrication of a couple of new ones but overall wasn't too bad. The AC belt was the worst of it. Had to relief cut her bracket also for the belt not to hit the bracket. In my opinion the AC belt needs an idler about midway between crank and compressor. I'm going to fab up one before the weather warms back up again. Her's keeps flipping under heavy acceleration. I think it's whipping too much.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
Couple of pics during mock up
this is no help but, I thought everything aftermarket needed some modification...lol
Erik, I mounted my A/C this way (see pic).
Reviving zombie thread
2021 Thread Resurrection
Anyone bought the complete V-belt system from CVF in the last few years? I'm helping a buddy, he has a cobbled collection of factory pulleys & brackets, along with a Vintage Air system, and keeps throwing belts. I thought this might be his solution, until finding this old thread!!
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
Their customer service generally gets stellar reviews.
I have a cvf bracket system but still using original pulleys. I have thrown a belt once but only at the top of the 1/4. Street driving I have thousands of miles no problem. I will say that on initial install I had to crank down the fasteners pretty hard to get proper alignment. What I felt was tight still left gaps between the brackets and spacers. 100% honestly while my experience is 90% positive if I had to do it over again I would buy a serpentine kit.
The Following User Says Thank You to RocktimusPryme For This Useful Post: | ||
It's been a few years since I did mine, but I've had to work on quite a bit of v-pulley set ups. To avoid throwing belts you should spend extra time in ensuring everything is aligned. If you get them aligned well, spacers, etc., the factory pulleys (that you have) or the CVF setup can be made to not throw belts. CVF will send out spacers to align things, but I found I had to make modifications to get it aligned properly.
The Following User Says Thank You to torqhead For This Useful Post: | ||
Just to say it out loud, timing cover condition, gaskets used, and water pump used, all impact the final result.
Serp and v-belt parts are based off the machined face of the block, anything from there outward can impact your final results. Almost all serp companies use, or 'suggest' you use, an Edelbrock water pump (suspect due to close tolerances). I suggest a new timing cover too. And use the typical thin paper gaskets on TC & pump/pump divider plate. Taking the above into consideration, you greatly increase your' chance of success. .
I've used OE and aftermarket (Ram Air Resto) V-belt pulleys with OE brackets to high RPMs on multiple vehicles and rarely to never threw a belt.
The same. RARE can drill the crank pulley for 3 bolt holes if using an ATI balancer.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune 13.43@103.4 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs Last edited by Skip Fix; 06-29-2021 at 04:37 PM. |
Out of curiosity, what are you guys using to verify alignment? Mine eyeball wise look very close, but I did toss a belt on a drag run. Specifically it looked like it flipped first and then came off. So I might be slightly out of alignment. But when you get close, how are you verifying that it’s dead true.
Put their V belt pully and bracket system on mine 2 years ago and it has been flawless.
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and 9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches.. |
The Following User Says Thank You to pokey1 For This Useful Post: | ||
Another 'just to say' comment, pulleys can and do wear out.
#38
I'm one of those drivers that make the motor work regularly, turn my v belt system to 6K regularly and have not thrown a belt for many years. |
#39
I am using original pulleys. I have considered going to knew CVF pulleys, but at the same time Im not sure I want to put more money into the V belts, or just go to a serpentine system.
#40
