300lbs in 1/8?
Anyone have any idea the et/mph improvement from removing 300lbs does for 1/8, roughly?
To give you a general idea, my 73 was 450lbs heavier than the 68, same motor & trans, 3.42 vs 3.50 gears. The 73 was typically in the 7.2 and 7.3xx range around 94mph while the 68 is in the 6.7 and 6.8 range around 103 mph depending on weather.
The 68 does have a better suspension setup , which of course will also contribute to the ET. Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
Wallace Racing has a calculator on there that is called New ET from weight change. You can input 1/8 mile data however I suspect it is meant for 1/4 mile.
And there is this: https://racingcalcs.com/eighth-mile-...h-incremental/ .
100 lbs is about .03 in the 1/8, so 300 lbs would be around. 09 to a tenth max. I have talked to people that have only seen .02 per 100 lbs. I took out 50 lbs 2 years ago on back to back passes and I didnt see anything.
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
Cool thanks! So a 5.36 might be 5.27-5.30 then.
Curious, with all else being equal, would a car using a tall rear gear (say 3.08) benefit more from the weight reduction vs the same car geared with 4.11?
GTO George |
O.15 to o.2 s
I'v seen 0.6 et gain per 100 lb 7.05 - 6.99 in the 1/8th
FMile Pontiacs, we know you meant .06 instead of .6 but that is still very good for 100 lb reduction. Back in the day you use to hear .1 for every 100 lbs but I always thought that was just wishful thinking.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
Stan
Prostreet64 you are correct. thanks, Joe
