Old 02-02-2017, 02:30 PM
FrankG FrankG is offline
Default IA II cast iron block update
Just want everyone to know that Cast Iron and Aluminum Blocks are in the machining process.
If you are looking for a block with special order items, such as a big cam tunnel, the time to order would be now.
We apologize for the long delay. The new, blocks with our latest improvements in casting and machining, will be ready for shipping beginning 2/15.
We have moved the CNC machining to a new building, within the same company, with new machines and dedicated operators. All of the CNC manufacturing is done in a cell with palletized robots loading and unloading the blocks. We now supply the blocks with the main and cam tunnels line honed to save additional machine cost.
The improvements include adding more cast Iron to the main webs. We now have to machine both sides of each web to match the caps. This removes any stress risers in this area to improve strength. The main webs are now a full 1". We have also down sized the oil feed hole to the cam bearings to 1/8 of an inch to keep more oil on the main bearings.
We thank everyone for their patience and look forward to keeping the Pontiac community supplied with the best possible products.
Frank G
Old 02-02-2017, 02:34 PM
Robert C.'s Avatar
Robert C. Robert C. is offline
Pictures of the changes.
Name:	Main Web Machined.jpg
ID:	446290   Click image for larger version
ID:	446291   Click image for larger version
Name:	Deck Surfaces.jpg
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 6.027@231.64
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
Old 02-02-2017, 03:03 PM
slowbird's Avatar
slowbird slowbird is offline
I have to ask, when will the revised Tiger heads be available?
Old 02-02-2017, 03:05 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good news! Thanks for the update.
Go fast, see Elvis!
Old 02-02-2017, 04:43 PM
Robert C.'s Avatar
I have the new casting going in the mill on Friday.
Then it will go for sonic checking and porting.
Don't be surprised if we have numbers in the 520ish CFM range. These prototypes have been near 10k rpm on someone's car already.
Bob C.
Boss Bird Funny Car
Old 02-02-2017, 05:19 PM
estep455's Avatar
estep455 estep455 is offline
does the down sized oil holes to cam journals cut down on the cracking in that area?
Old 02-02-2017, 05:53 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Nice!
Old 02-02-2017, 05:56 PM
John Langer's Avatar
John Langer John Langer is offline
When are you guys going to come out with a service replacement block good for 1000hp and a target cost of under $1,000... you would sell tons of them. Sorry, had to type that .
Old 02-02-2017, 06:02 PM
GTOGEORGE's Avatar
Thats......FUNNY! LOL!
GTO George
Robert C.'s Avatar
There is no reason to have a larger oil feed hole is the main reason to down size this hole.
And anytime you reduce the cross section you gain yield strength.
Machining the sides of the Mains is like polishing a crankshaft to reduce the surface imperfections. It makes it stronger.
We always try make a better product.
Bob C.
Boss Bird Funny Car
Old 02-02-2017, 06:03 PM
Robert C.'s Avatar
Put the crack pipe down and step out of the smoke John.
Bob C.
Boss Bird Funny Car
Old 02-02-2017, 07:38 PM
Tom Vaught's Avatar
Boost Engineer
Thanks, Bob and Frank, for your efforts over all of these years!
Tom V.
Old 02-02-2017, 09:06 PM
92GTA's Avatar
92GTA 92GTA is offline
This is a VERY exciting time to be a Pontiac enthusiast!!!!
Thank you!
1969 Pontiac Firebird
Old 02-02-2017, 09:16 PM
PAUL K's Avatar
Why would they cost so much?
Go fast, see Elvis!
Old 02-02-2017, 09:19 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What changes were made?
Old 02-02-2017, 09:26 PM
Tom Vaught's Avatar
Boost Engineer
Read Post #1 by Frank, the changes are there.
Tom V.
Old 02-02-2017, 09:30 PM
ponjohn's Avatar
Tom V.
Yeh thanks, I was referring to updates on the Tiger heads.
Old 02-02-2017, 09:49 PM
chiefbigb chiefbigb is offline
Good news!! That's allot of air flow. I would like to see a set if possible.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 02-03-2017, 02:14 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
How many pounds of iron added with the FAT main webs? They are impressive looking...
Old 02-03-2017, 06:35 AM
Robert C.'s Avatar
Jack our mains were already at .930 thick. The main caps are 1.00 thick. So we added iron to be able to machine them to match the caps.
This added 2 to 3 lbs. If that.
Bob C.
Boss Bird Funny Car
