Old 01-11-2015, 09:47 PM
Dick Boneske's Avatar
Default Grill Mount Brackets '67, '68 400
I need three of the right angle brackets that stabilize the bottom of the front grills on my '68 Firebird. I have one of the four pieces, but can't find the others. They are small steel 90 degree brackets about 2" X 2" with a single hole in each wing of the bracket.
If needed, I'll post a picture of the bracket.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 01-12-2015, 09:06 AM
68tpls400 68tpls400 is offline
FWIW, Those are being repopped now if you can't find originals.
Old 01-12-2015, 11:13 AM
I need only three of the four brackets. Here's what they look like--about 4" from end to end.
Name:	Grill Brackets, Firebird 015.jpg
ID:	387189   Click image for larger version
Name:	Grill Brackets, Firebird 017.jpg
BONESTOCK GOATS
Old 01-15-2015, 01:50 PM
I'll take anywhere from one to four pieces if you have them.
BONESTOCK GOATS
Old 01-15-2015, 11:07 PM
67GP428's Avatar
67GP428 67GP428 is offline
I might have some spares? I'll have to get back to you. Scott
Old 01-16-2015, 01:13 AM
Thanks, Scott. Let me know.
BONESTOCK GOATS
Old 01-17-2015, 06:55 PM
67GP428's Avatar
HI Dick. I found those 3 brackets your looking for. I had to make sure I had at least 4 for my Firebird. There blasted , primed and ready for paint. PM me if your still interested. Scott
Old 09-16-2023, 11:50 AM
68 461 Bird 68 461 Bird is offline
Do you have any extra's? I just need one.
Thank you!
Old 09-16-2023, 08:12 PM
Cammer-6 Cammer-6 is offline
those should have a rubber bushing in the hole so the peg fits tight
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 09-17-2023, 02:52 PM
That is correct!
Old 09-28-2023, 08:49 AM
Kent Christensen's Avatar
Kent Christensen Kent Christensen is offline
I have a set of 4 brackets without the rubber bushings for 40.00 plus shipping. They should fir in a small USPS box for 10.20 so total would be 50.20. I use paypal. 763-913-9573
Old 10-02-2023, 11:36 AM
Thank you Kent, I was trying to avoid buying a complete set since I only need one.
Old 10-02-2023, 12:28 PM
Then split them with the original request from Dick Boneske.
