SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 12-14-2023, 11:28 AM
HWYSTR455's Avatar
Default Moser 12 Bolt Rear, Car 68-72 A-Body
Moser 12 Bolt car housing, 68-72 A-Body (may fit other applications), 30 Spline Moser Axles (access holes, 1.75" disc brake studs), 1350 Pinion yoke, Moser cap brace cover, housing narrowed 1" each side for disc brakes.
NO DAMAGE to Housing, never in an accident, worn out guts in it.
NEW PARTS AS SHOWN IN PIC:
PYUBK U-bolt 1350 set - $7.00
R12B 12 Bolt setup kit with spacer & shims -$120.00
5TT555 TrueTrac 30 Spline Differential - $560.00
12B373 US Gear P/S Ring & Pinion - $220.00
ARP 230-3001 Ring Bolts - $35.00
9559 Axle Bearings & Seals - $55.00
7110 12 Bolt Aluminum Cap Support Cover (used, as shown) - $216.00
Case Spreader - $229.00
Total for Rebuild Parts - $1442.00
Asking $1500.00 for all of it, housing & axles basically free at this price.
PICKUP ONLY
Old 12-14-2023, 11:32 AM
HWYSTR455's Avatar
The setup kit has the spacer instead of a crush sleeve, and shims, to achieve pinion gear depth required.
Use the old pinion bearing slightly honed out, so it slides on & off pinion gear, for easy setup.
Housing has the Moser caps with ARP hardware.
Old 12-14-2023, 12:06 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
wheres this located? sorry i never can see locations on this site from my phone
Old 12-14-2023, 12:26 PM
HWYSTR455's Avatar
Winchester, VA
Old 12-14-2023, 12:32 PM
HWYSTR455's Avatar
If someone wants to organize pickup, crating, & shipping for themselves, I'm willing. I just personally don't want to deal with it.
Old 12-14-2023, 05:05 PM
SHAWN MILLER's Avatar
SHAWN MILLER SHAWN MILLER is offline
Are the spring pads and lower control arm mounts moved in? They dont appear to be in the stock locations. do you have an outer flange to flange measurement at the axles? Thanks, Shawn
67 GTO 455,Super T-10,Wenzler Ram
79 Trans Am 455 Pro Stick Racing
2005 Thunder Mountain Blackhawk 103"
2019 Street Glide 114"
Old 12-14-2023, 05:17 PM
HWYSTR455's Avatar
The are in the factory locations.
Flange to Flange measurement is 61" as best as I can measure, it's probably a hair less, the cover prevents getting a straight shot when measuring.
Old 12-14-2023, 05:19 PM
HWYSTR455's Avatar
It might be 3/4" narrowed each end. I would have to dig up the paperwork, and I recently moved.
Old 12-14-2023, 05:21 PM
HWYSTR455's Avatar
This rear was in my 1971 LeMans for years, with disc brakes.
Old 12-14-2023, 05:28 PM
HWYSTR455's Avatar
Here is a pick from my build thread with it cleaned up and installed.
Old 12-14-2023, 09:53 PM
AG's Avatar
AG AG is offline
Does that have raised upper control arm mounts?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 12-15-2023, 07:21 AM
HWYSTR455's Avatar
Not that I'm aware of, not sure Moser even offers that.
This is a direct replacement for an OE rear, aside of the @ 1" narrower on each end.
I ordered it that way because I planned to run disc brakes, and it compensates for the rotor/brake setup that normally pushes the wheels out.
Old 12-16-2023, 11:58 AM
PM Sent. Thanks, Shawn
Old 12-16-2023, 12:26 PM
HWYSTR455's Avatar
PENDING PAYMENT
PENDING PAYMENT
Old 12-20-2023, 10:35 AM
HWYSTR455's Avatar
SOLD SOLD SOLD SOLD
SOLD SOLD SOLD SOLD
SOLD SOLD SOLD SOLD
