Old 10-20-2023, 07:25 AM
RAIIIJudge's Avatar
RAIIIJudge RAIIIJudge is offline
Default Dangling Wire ?
was under rear end yesterday when I found this guy. assuming it's from fuel sending unit. anyone recognize? fuel gauge works fine btw.
thanks,
mike
MA
Old 10-20-2023, 09:45 AM
Bill Hanlon's Avatar
Give us a hint. What car year and model? What color wire?
Old 10-20-2023, 01:03 PM
RAIIIJudge's Avatar
oh shoot, sorry!
69' GTO .. black wire
I'm thinking ground ? wonder why fuel gauge would be working if ground wasn't attached
thanks!
mike
Old 10-20-2023, 01:19 PM
dataway's Avatar
dataway dataway is offline
Yep, that's what it looks like. Gauge could be finding a ground through the tank somehow ... if a strap isn't fully padded, or filler neck touching metal etc.
Looks like that's the frame ground end of the wire hanging, if you can see where it attached to the frame put a new connector on it and reattach to the frame.
Old 10-20-2023, 01:50 PM
OG68 OG68 is offline
Attaches to the vent hose clamp
ID:	621956   Click image for larger version
2007 Cadillac SRX
The Following 3 Users Say Thank You to OG68 For This Useful Post:
Old 10-20-2023, 03:22 PM
RAIIIJudge's Avatar
ah ok .. even tho it's dangling at front side of tank .. idea is it goes over top of tank and grounds at vent clamp?
car's been home, in pieces, since June and it's basically been my full time (day) gig. she's rolling down the road (stealthily around the neighborhood) for first time since 95'.
finally seeing light at the end of tunnel.
pretty sure I can have everything at least hung before the cold.
thank you, fellas
M
ID:	621961   Click image for larger version
Old 10-20-2023, 04:57 PM
The other end is soldered to the tank sending unit.
ID:	621966   Click image for larger version
2007 Cadillac SRX
