I want to hear my new motor run and im about to try it out and have a small problem, ok?? What throttle bracket can i use on the rpm intake?? I have the 67 gto throttle cable there but i don,t think the 67 bracket will work?? I need ideas on what your running?? Pictures, anything?? Im excited and can,t wait to hear it run, please help me out asap!! Im all ears and waiting??
you have to cut it. At least mine came cut.
works on the rpm intake. just by mounting bolt you see it was hacked so there is no bottom piece which usually mounts to the intake bolt.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
Looks like your throttle cable comes in at a differant place than mine. is that a 66-7 gto? don,t mind me asking whats the black wire running next to the throttle cable??Temp. sending unit wire??
Yup, correct. temp wire
67Cruiser,
Lokar, B&M and Summit list a bracket to use the GM cable with an Edelbrock manifold. I am sure PY carries them too
Its ok to giggle and snicker, Dont laugh and point |
Wnet with the Lokar on my 68...I got the cable and bracket kit, works great.
"mean" |
What I had to do is buy the adapter bracket from edelbrock. Then I had to bend the long tab on the trottle braket up. Bolted it on and it works fine.
