Old 02-01-2024, 08:51 AM
67Lemons 67Lemons is offline
Default Lifter Resurfacing
With all the concerns about HFT lifter & cam failures I decided to purchase a set of slightly used GM lifters from the 80’s or 90’s for a really good price. The story was that they were used for 5 dyno pulls then swapped out for a roller cam. All the lifters do look like they were only used for a few pulls, two or three have some marks on the face that I can’t feel with my fingernail, pic is below. Regardless my plan was to have them resurfaced so before I pick a place randomly I figured I’d ask the group if there’s a place that you know of that will do the resurfacing?
ID:	627663   Click image for larger version
Old 02-01-2024, 09:03 AM
Jay S's Avatar
Jay S Jay S is offline
Camcraft cams
Egge Machine
https://mizpahprecision.com/pricing.htm
qppcams
I believe Schneider racing cams resurfaces lifter also.
Old 02-01-2024, 09:12 AM
77 TRASHCAN's Avatar
Paul Carter
Shut it off
Shut it off
The Following 2 Users Say Thank You to 77 TRASHCAN For This Useful Post:
Old 02-01-2024, 09:23 AM
Jay S's Avatar
Carter could cryo the lifters too.
The Following 3 Users Say Thank You to Jay S For This Useful Post:
Old 02-01-2024, 09:48 AM
Paul Carter
Do you have contact information for him?
Old 02-01-2024, 02:23 PM
Pav8427 Pav8427 is offline
Hopefully not off track.
But with things the way they are today, would this be a 'blueprint' operation to consider?
Most know how this works.
You have pistons in hand before final hone.
You have main bearings in place and measured before grinding crank.
You get the idea.
Disclaimer. I dont have a lot of real world experience, but being a machinist I think about this shtuff.
For sake of discussion lets assume we have good quality parts and machine work is accurate.
Numbers/design are just for theory only.
So picture this. We have a lifter on cam.
Left side of lifter is in line with cam lobe.
Cam lobe tapers .010 down to right.
Lifter has crown of .005
You guys with parts in hand could give an idea on real world numbers.
So now we have cam company A that has these dimensions.
Now some prefer to mix and match companys.
So company B's lifters have .003 crown.
Installed on A's cam you lose .002.
Would this be a case where one would want to have the cam in hand and grind lifters to 'match'?
I know brand and breed of engine design comes into play.
And level of build also. IE. Backyard build vs. Nascar build.
Whats your experience or opinion on the matter?
The Following User Says Thank You to Pav8427 For This Useful Post:
Old 02-01-2024, 04:33 PM
242177P's Avatar
242177P 242177P is offline
I've always thought of it like setting up a ring and pinion. The 'pattern' of where the lifter rides on the lobe isn't going change appreciably based on it's crown alone. The taper on the cam would have a more significant role? Dunno.
Old 02-01-2024, 05:12 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
that is a good question. how about add to the fact a cam can be given to some companies who can build up the specs to what you want by adding material!?
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 02-01-2024, 08:11 PM
520-409-7236
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 02-04-2024, 08:20 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Oregon Cams regrinds lifters also. You have disassemble them and only send the lifter body. They advise to keep the internal parts together and don’t mix and match on reassembly.
Price is pretty reasonable.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
The Following User Says Thank You to TCSGTO For This Useful Post:
Old 02-04-2024, 01:10 PM
Stan Weiss's Avatar
You get the idea.
This might be an interesting read.
Lifter face radius question
https://www.speed-talk.com/forum/viewtopic.php?t=46101
Stan
Pontiac Pump Gas List
The Following 2 Users Say Thank You to Stan Weiss For This Useful Post:
Old 02-04-2024, 04:51 PM
Schurkey Schurkey is offline
If those lifters were mine, I'd verify that they still have some crown. If they do, I'd pull 'em apart ONE AT A TIME for cleaning and inspection of the guts.
Assuming they look OK inside, I'd put a piece of exceedingly-fine sandpaper (1000 grit?) in the palm of my hand or on some firm closed-cell foam like a better-style water-ski life vest, twist the lifter foot against the sandpaper for about two seconds, wipe 'em off with a soft cloth perhaps with some solvent.
The Following 2 Users Say Thank You to Schurkey For This Useful Post:
Old 02-04-2024, 05:46 PM
dataway's Avatar
dataway dataway is offline
I'd love to see any HFT cam, and any set of lifters sent to "someone" who could positively put proper matching lobe taper and lifter crown on the items, then install in engine and see how it goes.
Don't know of anyone that would do this sort of thing ... but I'd bet if the parts were decent quality to begin with, that it would break-in and run beautifully.
Old 02-04-2024, 06:09 PM
242177P's Avatar
... twist the lifter foot against the sandpaper ...
David Vizard recommended figure eights, but his approach was more aggressive
The Following 2 Users Say Thank You to 242177P For This Useful Post:
Old 02-04-2024, 06:55 PM
A friend of mine chucked some lifters in a drill press and made a jig to swipe the lifter bottoms, restoring the convex deal and improving the surface. David Brown 880 3 cyl diesel tractor lifters were never very common...
Shut it off
Shut it off
Old 02-04-2024, 06:58 PM
1968GTO421's Avatar
My thanks to Stan for posting his link to SpeedTalk. Very interesting and that link had a link within it to EngineBuilder which was quite helpful. Below are links to the two sites mentioned. Thank you Stan.
https://www.enginebuildermag.com/200...owned-lifters/
GTOAA--https://www.gtoaa.org/
The Following User Says Thank You to 1968GTO421 For This Useful Post:
