So, I have to ask. Where is the 4000.00? |
Do the castings still come without the guides and seats installed?
My understanding is they come with very small ports, no chamber bowl work, and no guide installation. RAW CASTINGS. Chunks of aluminum.
Tom V.
Correct, which causes machinig time to go way up.
Casting cost twice as much as a bare rpm e-head
No reason for you to have a 8K set of heads. NA guys need them, you don't. Marty rocked tiny D ports and we all know what he did . Looking forward to see how your car ends up. Keep doing what you are doing. |
When I shipped my raw Pro Port castings to BES each head weighed around 48lbs. It will be interesting to see how much they weigh when I get them back.
Jim 71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas |
So they have new pricing. They used to be in the 2000.00 range for a pair.
Looking at BES's web site I notice it lists this as the small port program. Does anyone know if they have a large port program for Pontiac?
Stan
So all of you 1.000 inch cam lift guys post up your camshaft specs.
I personally concentrate on the .800 inch lift flow numbers. About 440 cfm. Tom V.
anyone compare cost from BES to cost from Butler ---?????
Bigger port means more power at the same boost |
Yet Chief can run a head with 130+ more cfm, but does not. If he put much larger heads on he would have to make a bunch of changes to be at the same boost he was before. He makes about the same power with his puny little inline junk heads as that TT billet block canted valve Warp 6 engine that flow much, much more with a much larger CSA. He has very good people like Quinlan working with him. Using his program for a example would be wise IMO. I think CSA is going to matter much more than cfm in a boosted engine since the limiting factor is the smallest section of the port and the size of the valve and you are just shoving air though it with a giant pump. A good NA port needs to accelerate the air simply based on vacuum, difference in pressure from one side to the other. Science and shape matter more . Supercharged is boosted right ? |
Sean a video chief did, he said his e heads flow 330.
Yep, and they look pretty big for a head that only flows 330cfm. A big hole matters more for what he is doing. Kinda looks like a LS port.
Butler and Tony B are partners in the deal. No difference in prices.
Tom V.
#38
Stan
#39
Not sure that Travis has much time to help Chief the last couple of years.
Chief has got it figured out. Travis is working for NASA so he is not helping guys tune their engines much these days, from what I understand. Course there is still the phone. But I will agree Travis Q is a very smart guy and a excellent high HP Tuner. Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
#40
You been smoking some of that stuff ?
Justin is not always on rocket fuel. NPK does not allow it. And he has a win under his belt I believe. How did your beloved heads work out with him ? |
