Old 10-31-2021, 03:10 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Default Melling M54D oil pump
I just took apart a Melling oil pump to see if there were any issues before putting it into my new 463. I think you can see from the photo that the gear teeth have some striations along the leading edges, especially on the driven gear. Is this a problem that would effect the efficiency of the pump? There is also some wear on the cover where the gears make contact. I assume this is normal.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
Old 10-31-2021, 04:30 PM
Vengeance Race Engines's Avatar
Vengeance Race Engines Vengeance Race Engines is offline
It's common to see that stuff, regardless of brand. Problem running it? Not that I have seen. Just looks ugly.
Old 10-31-2021, 05:08 PM
I would sand the scratches out of the cover on some soapy wet or dry 220 grit sand paper in a figure 8 motion and put it back together with blue Loctite after all the oil is off the bolts and out of the bolt holes and running it again!
Old 10-31-2021, 08:15 PM
Yea, I will clean it up and run it again. That is what I was hoping for, not to have to replace it if not needed. Thanks.
