Old 10-16-2021, 04:21 PM
Peckels Peckels is offline
Default victor Edelbrock heads
I thought these heads were discontinued like 5 years ago . Now BES is selling them . maybe an old ad i guess
//www.besracing.com/cylinder-head-and-intake-packages/cylinder-heads/pontiac/bes-edelbrock-victor
Old 10-16-2021, 06:33 PM
https://www.besracing.com/cylinder-h...elbrock-victor
Old 10-16-2021, 06:41 PM
CNC Ported by BES, 460cfm
https://butlerperformance.com/i-3164...tegory:1234765
Old information here:
Old 10-16-2021, 07:19 PM
Scott Stoneburg's Avatar
Its possible that BES or Butler purchased them while they were still available from Edelbrock and have not sold out of stock yet. But I understand that Edelbrock stopped making these a while ago.
Old 10-16-2021, 07:52 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Geez 411 cfm at 600 lift.
Old 10-16-2021, 10:52 PM
Off set rockers on the intake ?
Old 10-17-2021, 01:39 AM
opeliac opeliac is offline
BES and Butler are the ones that the heads are being produced for, as a signature head.
Old 10-17-2021, 11:34 AM
slowbird's Avatar
slowbird slowbird is online now
Wish they have a starting point price
Old 10-17-2021, 11:37 AM
I'm with ya on that one...David Butler was telling me about this deal a few weeks ago...Should be a good head for sure...I just got my Eheads from AP, and my Ti/In valves, or else i'd go that route...
Old 10-17-2021, 12:30 PM
Jegs has raw price.. $2,300 plus change for a pair
https://www.jegs.com/i/Edelbrock/350/77849/10002/-1
Clay
Old 10-17-2021, 12:33 PM
Stan Weiss's Avatar
The number I have from sometime ago for Pro Ports by John Marcell. Only have Intake numbers. Note it has a smaller 2.30" valve.
.300 243
.400 318
.500 380
.600 434
.650 447
.700 460
.800 466
.900 460
Stan
Pontiac Pump Gas List
Old 10-17-2021, 12:57 PM
Clay
Thats probably the old deal...The new ones may be only available through Butler or BES
Old 10-17-2021, 06:39 PM
From Jegs
"Estimated to ship direct from manufacturer on 10/27/21 , pending manufacturer availability."
Clay
Old 10-17-2021, 08:51 PM
From Jegs
Clay
Jegs, and Summit, have always said they were available, even when they werent...
BUT...The new ones very well may be able to be bought from them...I havent heard for sure.
Old 10-27-2021, 07:03 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Sorry,Maybe little off topic. I’m sure if I do enough research I could see the difference in the E heads. I seem to think there may be three or four generations in at this point ? Can anybody educate me on the differences between the three Please. I know one was to help oil return the pan I don’t know the rest of the differences is there a fault in any of the designs that I should not use any longer? I do have an early set of Butler 370 wide ports. not sure if I should retire them? Motor is apart for fresh in up. But look good.
Old 10-27-2021, 10:40 AM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
How available are the pro port E heads and is anybody running them, flow numbers look good. I see BES and Butler show them.
Old 10-27-2021, 03:49 PM
I believe that Tony B and David Butler have the only ability to sell the heads at the current time.
I understand they have some castings and IF you have the $$$$$, Tony will finish them to either 440 cfm or 460 cfm.
I talked to David B about this head a week ago.
Old 10-27-2021, 04:33 PM
JD's Avatar
JD JD is offline
BES does have a batch of 11 degree heads for the add posted above. You can call BES and talk to Preston to get the exact price but I think they will be around $9000 complete without rockers. I was quoted $6800 if I supplied the cores.
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
Old 10-27-2021, 08:01 PM
My ported e heads, with titanium and incolnel valves, with good parts are less than 5000.00 ported and ready to bolt on. 9000.00 doesn’t make a lot of sense to me. Considering the cores are close to the same price, port work should be close, and all of the parts are the same. Where does the extra 4000.00 go?
Old 10-27-2021, 08:23 PM
What does your heads flows?
