Old 03-20-2020, 09:05 AM
64gp4spd 64gp4spd is offline
Yes the diameter is the same. No proportioning valve just a junction block
Where the brake lines connect to
Old 09-07-2023, 11:35 AM
WQ59B WQ59B is online now
Just finishing the dual MC conversion on my '64 GP power drum car. Used a '69 Bonne MC- they come in both 'deep' and 'shallow' pushrod depths (I think it was 3/4-in and 1 5/8-in). My car had the longer pushrod and the MC fit the pushrod fine.
The '69 Bonne MC requires (different sized) adapters in both ports to fit the lines. These were harder to track down and ultimately came from 2 different parts places (and one was the state-wide NAPA distribution warehouse- only had one of them).
This did push the brake lines very close to the inner fender, I found a cheapie bender at Harbour Freight that did tight enough bends that cleared the fender by about 1/8-in.
A word of caution - I bought stainless lines from Inline Tube- most of the flares were of very poor quality RE the sealing surfaces- a lot of gouges. ended up disconnecting everything and slipping copper flare washers at the end of every SS line. Never again with SS. They're also basically impossible to re-flare if you need to shorten a line- the SS is just too hard.
Finally- all 3 brake hoses Inline Tube sent me were incorrect- the rear was male/female and the front connections were too small to accept their own flared lines! Had to replace all 3 locally.
The Following User Says Thank You to WQ59B For This Useful Post:
  #143
Old 09-11-2023, 07:02 PM
webfoot's Avatar
webfoot webfoot is offline
CuNi line is a sinch to both flare & bend, very easy to work with.
There is a MC from certain model of cadillac that has the MC lines pointing to the RH side of the car, I think an El Dorado - i'd have to look it up again. Wish I had found that out before I notched my inner fender.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
  #144
Old 09-11-2023, 11:20 PM
Mario64's Avatar
Mario64 Mario64 is offline
IIRC 1962 cad deville has ports on the engine side. I have one unused if someone needs it.
Ciao,
Mario64
  #145
Old 11-29-2023, 11:31 PM
RE my post 3-posts back, I have a couple of issues ~
1. the closeness of the inner fender and the adapters required on my MC to connect the lines to (which then moved the lines farther outboard), forced me to loop the brake lines at the MC UP, and I think that's trapping air. I think the answer may be to swap in another MC with the standard size ports, and rebend those lines.
2. which reservoir feeds the front brakes, the one closer to the booster or the other? The MC I current have has different sized outlet ports (hence; the adapters), which seems to strongly suggest there's a preference. Recap: '69 Bonne MC for power 4-wheel drum brakes.
  #146
Old 11-30-2023, 02:19 PM
misterp266's Avatar
Here’s the MC I ended up getting for my ‘63 Catalina.
Fittings on both sides and can be used with or without a booster and can be used for drum-drum or drum- disc setup. I got the aluminum version for less weight and no rusting. Going to change to a cad plated cover.
No, it has not been plumbed yet. Plan to use the outside ports and an adjustable distribution block. Scarebird disc on the front and drum rear. Manual brakes.
https://piratejack.net/gm-universal-...ster-cylinder/
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post:
  #147
Old 01-10-2024, 09:55 PM
Have bit the bullet and procured a '65 Cadillac MC- it's ports are on the engine side and aren't oddball-sized / requiring adapter fittings. Hope to mount next week and resume bleeding.
  #148
Old 01-12-2024, 11:16 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
I did it on our 66 Chief to original booster when I did the 70 Bonne disc swap , needed the deep hole plunger got a Dorman 68-70 Corvette ish unit new for $36 on Amazon free shipping
https://youtube.com/shorts/Hb1y3nZm5...K8Ubm043PBaMWZ
https://www.youtube.com/watch?v=SvfDYPvQsC4
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
