Old 12-06-2009, 12:37 PM
Bob Arthur's Avatar
Bob Arthur Bob Arthur is offline
Default gas leaking at sending unit
I installed a new OPGI gas tank in my 66. I installed a new sending unit before installing the tank. I was very careful to center the unit and O-ring before turning the tabs. It was OK for a month. It started leaking at the sending unit. I pulled the tank and put a new O-ring in it then reinstalled the tank. It is leaking again. Could I have a bad tank or?
Bob
Old 12-06-2009, 12:42 PM
67cruiser 67cruiser is offline
Bob , to be truthfull, your the first person i heard of having trouble. May i ask you, was the o ring a tight fit when you locked in the unit??
Old 12-06-2009, 12:58 PM
Bob Arthur's Avatar
It did not feel as tight as I thought it should.
Bob
Old 12-06-2009, 01:13 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
It's the o-ring causing the trouble, it needs to be thicker. When you turn the ringed tab it should be a pain in the neck to turn because the fit is so tight. I had the same issue the last time I swapped a tank. Do you have the factory o-ring? If you compare the two you'll see the difference. Good luck! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 12-06-2009, 01:26 PM
Bob Arthur's Avatar
Your right. I guess I have to pull the tank again. Installing the sending unit with the tank in place is a real pain...
Bob
Old 12-06-2009, 01:27 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
Last time I checked, the factory lock ring and o-ring were still available from the GM dealer....order one of each......
Old 12-06-2009, 01:35 PM
Bob Arthur's Avatar
Thanx, I will check it out.
Bob
Old 12-06-2009, 01:48 PM
I have a new o ring and lock ring right here for 8.00$ if your interested
Old 12-06-2009, 01:53 PM
Bob Arthur's Avatar
Are these the GM parts?
Bob
