Old 08-09-2021, 12:39 PM
mgarblik mgarblik is offline
We ran limited vacuum as well in the system with an adjustable valve. 12"HG for us and we monitored it with the data system. Real high vacuum in the crankcase with wet sump oiling and pump in the pan, the pump is working against the vacuum. Our Moroso consult felt the 12" HG was a safe max number for a stock Melling pump which we were running at the time. He mentioned the dry cylinder wall and pin oiling issues at high vacuum, but didn't really believe it was a factor nor did he have any hard data. I tend to think that's mostly speculation as well. When you have a guy like Langer running 19" HG at speed with no issues, at what I assume is high RPM's, that tells the story IMO. Picking up vacuum from the front of the valve covers for drag racing seems like a fine idea and worked for us through a baffle system. For our road race engine, picking up in the center, inboard, high in the cover I like because of the high acceleration forces as well as high braking forces. Nice compromise.
Old 08-09-2021, 12:44 PM
chuckies76ta's Avatar
(For our road race engine, picking up in the center, inboard, high in the cover I like because of the high acceleration forces as well as high braking forces. Nice compromise. )
Great info. Thanks. I could see where that makes sense as the oil flying back and forth throughout the road race . Also, like you said HIGH in the cover.
Old 08-09-2021, 01:12 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
I've tried many baffles and locations. I ended up welding a bung at the top in the center and made my own baffle inside. Welded some flat stock in a few spots, the ends are wide open. I pull 16-18 at the stripe.
Name:	vc inside.jpg
ID:	571012   Click image for larger version
Dave Polichena
Old 08-09-2021, 01:18 PM
That looks nice as well. Not sure we have room for quite that much of a baffle. Going to be running some big, clunky stainless steel rocker arms. (Crower)
Old 08-09-2021, 04:20 PM
gman005's Avatar
gman005 gman005 is offline
Yes i run the adjustable relief valve. I will post a picture of that.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 08-09-2021, 04:25 PM
gman005's Avatar
Default Pic
Here is the valve.
71 Lemans Sport.
72 Lemans Sport.
Old 08-09-2021, 04:49 PM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
I added the adjustable valve last year to my EVAC pump.
With mine adjusted to 14" at the big end, at 2021 Norwalk it had maybe a table spoon in of oil in the catch can after each run compared to years past of a cup or more.
Also added a sweat band around the catch can breather which worked great.
Bob,
Name:	EVAC Valve 2021.jpg
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 08-10-2021, 08:39 AM
Don 79 TA Don 79 TA is offline
Originally Posted by John Langer View Post
A hair over 13.1-13.4 at an idle and around 19 in the lights.
how the heck are you getting that much at idle?
must be a super sealed up engine or spinning a pump like crazy
i get about 3 with the GZ102 pump at 5k altitude idle 1100-1200
what pump are you running?
first time i've heard anyone getting that high
Old 08-10-2021, 09:09 AM
slowbird's Avatar
slowbird slowbird is online now
A good pump makes a big difference, my star pump will pull around 10 at idle.
Old 08-10-2021, 09:37 AM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Now my question is what is the best pump to use? I have a 14:1 535 I would like to add the best pump I can afford to because I have no windage tray or crank scraper and I have low tension rings. I want it to live a long life and I want the advantage of the increased power!
Old 08-10-2021, 10:01 AM
slowbird's Avatar
Star or 4-vane Moroso are the 2 best imo
The Following User Says Thank You to slowbird For This Useful Post:
Old 08-10-2021, 05:22 PM
cgeise's Avatar
cgeise cgeise is offline
Haven't seen it addressed here yet so here goes --- If your engine has any leaks -- or excessive blow by the vacuum the pump will pull oil mist and fill the tank -- It has to be sealed --- think off it like this -- put a straw in an open glass of milk and suck -- you get lots of milk -- put a straw in a tight sealed container -- and the straw sucks shut and you get no liquid --
The Following User Says Thank You to cgeise For This Useful Post:
Old 08-10-2021, 05:23 PM
cgeise's Avatar
Oh -- and 69 goat -- the Star pump wants to be run with no or very little oil going thru it -- Moroso is more oil forgiving
Old 08-11-2021, 03:50 PM
Can someone post a picture of where you are checking vacuum? Does anyone ever use a breather on other cover to control vacuum?
Old 08-11-2021, 04:12 PM
gman005's Avatar
I pull from the valve cover. I am using the GZ pump. I have around 5 at idle and 11 at WOT.
71 Lemans Sport.
72 Lemans Sport.
Old 08-11-2021, 04:22 PM
gman005's Avatar
Here's the picture.
71 Lemans Sport.
72 Lemans Sport.
The Following User Says Thank You to gman005 For This Useful Post:
Old 08-12-2021, 08:42 AM
I tapped into the valve cover cap for a temporary set-up just to adjust the EVAC valve.
Name:	EVAC Temporary guage 1.jpg
ID:	571249   Click image for larger version
Name:	EVAC Temporary guage.jpg
The Following User Says Thank You to Bob with the 66 For This Useful Post:
  #38
Old 08-12-2021, 09:15 AM
Go back and read post #20. In a word NO.
  #39
Old 08-12-2021, 09:40 PM
Dragncar Dragncar is offline
Wow Sir, I can see have some Marcella stuff going on there. Can we see some more pics of the car/engine ?
From what I can see, work of art.
  #40
Old 08-13-2021, 09:33 PM
John Langer's Avatar
John Langer John Langer is offline
Most in my class pull over 22 in the lights. I run the Moroso 4-vane enhanced pump. I guess I could pull more if I was a dry sump. My motor is sealed up tighter then a submarine. Great ring seal and no leaks are key. If my vacuum starts to drop off during a run but has great pressure until then, its time to replace the rear main seal. I don't spin the pump too hard. I have a blow off valve but it is screwed all the way in and I have duct tape over it.
