Old 03-31-2016, 01:29 PM
RAMAIR RICK RAMAIR RICK is offline
Darren, If you are open, I have a simple crazy idea, YOU could buy Don Johnston's 455ci. Pump Gas DCI Ram Air V engine that makes at least 650hp and has been engineered out and runs and runs well. Check out his video on Youtube, very impressive for sure. That engine could go into your street car very quickly and you can enjoy it!! THEN if you want to build a VERY High End Race engine with DCI Ram Air V heads on it you can go to a professional engine builder and sit down and make a plan that will fulfill your Race Car Goals with reliability.
Darren then you will have fun with BOTH of your Cool cars!!
  #1142
Old 05-10-2016, 11:20 AM
dci dci is offline
Rick, I think our estimate was a bit on the conservative side LOL. 760 HP and climbing on pump gas.
Thank You to everyone that has followed my endeavor and supported me through the long wait. Please stay tuned I think more good things are going to come. Now I need to get the engine in my car and lay down some numbers !!!!!!
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #1143
Old 07-01-2016, 02:52 PM
dci dci is offline
Just shipped a set of 500+ cfm DCI RA5 heads to a guy up in Minnesota. I don't think he will be putting the engine together before late fall, but when he doe's get it together. I will let everyone know what the results are. He says he is going to dyno it when done.
ID:	431878   Click image for larger version
ID:	431879   Click image for larger version
ID:	431880   Click image for larger version
ID:	431881   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1144
Old 07-01-2016, 03:40 PM
smokey 1978's Avatar
smokey 1978 smokey 1978 is offline
Send a message via Yahoo to smokey 1978
nice job Don!
Albert Marquez
1965 GTO TWIN TURBO DCI RA5!
  #1145
Old 07-01-2016, 03:43 PM
slowbird's Avatar
slowbird slowbird is offline
Valve sizes?
  #1146
Old 07-01-2016, 05:43 PM
dci dci is offline
Originally Posted by slowbird View Post
Valve sizes?
2.300 intake, 1.68 exhaust
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1147
Old 07-01-2016, 07:51 PM
455firebird1969's Avatar
What a difference ten or twenty years make! Congrats Don!
  #1148
Old 07-02-2016, 07:35 AM
mysticmissle's Avatar
Those are looking great. Can't wait to see some track results. any approx cam and displacement information? Good luck Kevin
  #1149
Old 07-02-2016, 10:54 AM
dci dci is offline
Thanks guy's !!!!! When I look at these heads compared to even my Tiger heads I just cannot believe how big the ports are. 10 years ago we would have all said that there is no way they will make power LOL. The evolution from our beloved factory iron heads that we all had to run for so long, Seems like light years away now. I took a couple of pic's with a factory iron intake gasket over top of my RA5 heads. It's hard to tell in the pic's how big these ports really are, but you will get the idea. Obviously these are not low rpm heads after a race port job, but that's not the intended use of these heads. We know now that the as cast version makes incredible torque on a 455 with pump gas. So now we need to see what these things can do in a big inch high compression high rpm application. I'm doing a set for Danny Estep right now that I'm trying real hard to get completed before Norwalk this year. Time is not on my side, but I will give it my all. Danny is doing everything he can as well to help make this happen and without his help it couldn't be done for this year. As it is we are all going to be burning the midnight oil.
ID:	431932   Click image for larger version
ID:	431933   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1150
Old 07-02-2016, 11:06 AM
Stan Weiss's Avatar
Don,
500 cfm with 2.30" intake valve. What are you seeing on your flow bench? My rough calculations show a Discharge Coefficient of just about 1 at the throat.
Stan
Pontiac Pump Gas List
  #1151
Old 07-02-2016, 11:07 AM
dci dci is offline
Here a couple more pic's from different angles. I put a factory RA5 intake gasket in the stock location so you can see how much I raised the intake ports too.
ID:	431935   Click image for larger version
ID:	431936   Click image for larger version
ID:	431937   Click image for larger version
ID:	431938   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1152
Old 07-02-2016, 11:23 AM
dci dci is offline
Don,
Stan
I'm not sure that I'm following you Stan. The lift is 1.00" and the throat is 93%.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1153
Old 07-02-2016, 11:48 AM
Stan Weiss's Avatar
Don,
@28" water
5/16" valve stem
► (500/((((2.3*.93)/2)^2*pi) - ((.3125/2)^2*pi)))/146 = 0.97381
11/32" valve stem
► (500/((((2.3*.93)/2)^2*pi) - ((.3475/2)^2*pi)))/146 = 0.97886
Which should show an average velocity of 341-343 fps @ the throat.
Stan
  #1154
Old 07-02-2016, 01:49 PM
dci dci is offline
Don,
@28" water
5/16" valve stem
11/32" valve stem
Stan
I got ya !!!! 5/16" stem 28"
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1155
Old 07-02-2016, 03:28 PM
dci dci is offline
For comparison I took a couple of pic's of a set of Brodix BB2 Big Block Chevy heads I just done for a customer. The Chevy heads flowed 390 cfm @1.00" and 28" with a 2.375" valve and ported. I did not port them and don't know who did. My head is just in the rough in stages in these pic's.
ID:	431953   Click image for larger version
ID:	431954   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1156
Old 07-05-2016, 11:02 AM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Those heads look sick!
Keep up the good work guys
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
  #1157
Old 07-05-2016, 07:24 PM
Curious George's Avatar
Curious George Curious George is offline
Was it me? I live in Minnesota.
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
  #1158
Old 07-05-2016, 09:01 PM
dci dci is offline
Could be you, all I need is a check !!!!!
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
