Old 10-29-2009, 08:55 PM
Z Code 400 Z Code 400 is offline
Have you seen's Jeg's version of these wheels????
  #62
Old 02-05-2011, 11:56 AM
pontiacphil pontiacphil is offline
Default Backspacing on new Torq-Thrusts.
I'm still shopping for tires & wheels for my 67' GTO. I like the looks of the new American Racing Torq-Thrust Originals (TTO, 309 series) & the prices at Summit & Jegs are reasonable. The 15x7's are around $170 each. What concerns me is that this particular wheel has a 3.75" backspace where the 15x7 Factory Rally ll wheel has a 4.25" backspace. Don't know why American Racing uses this smaller backspace as their "standard" size. Will this half-inch smaller backspacing make a big difference? I would like to run a 235x60x15 all the way around but could go a bit smaller (225x60x15) if that would prevent any rubbing/interference/scrapping problems. I just want to find a proper fit that won't create problems. Any info. or advice any of you can provide will be appreciated.
  #63
Old 02-10-2011, 07:52 PM
Ken K Ken K is offline
For whatever reason the 15X7 Appliance wheels are more plentiful than the vintage Americans.
  #64
Old 12-31-2013, 07:41 PM
hotrodrx's Avatar
hotrodrx hotrodrx is offline
Default Recommendations appreciated
I want to go with Torq thrust 2's on my 67 conv gto .
I am thinking 17 x 8 rear and 17 x 7 for the front. What size tires? Car color is Corvette Carlisle Blue, so I was thinking blue lines?, or red lines. Suggestions are appreciated. Bill
67 gto conv. cover car on gto buyers guide, numbers matching,
62 catalina siverleaf green
67 gto conv. M22 , stroker, roller 400, carlisle blue, parchment interior
65 stingray original condition numbers matching 327 365 hp
  #65
Old 02-02-2014, 05:55 AM
demonic68's Avatar
demonic68 demonic68 is offline
I have always loved these wheels i always wanted to get a set for my 68 Lemans there is no way I could ever stand the wheel sticking out of quarters
  #66
Old 11-17-2015, 11:32 PM
powerhaulic's Avatar
powerhaulic powerhaulic is offline
I got these 2 years ago
love the look of the original style
Apparently my files are too big........
'11 GMC Yukon XL Denalli AWD
'66 ElCamino
'71 C10 Cheyanne Super
'68 400 Bird Ragtop
  #67
Old 11-17-2015, 11:39 PM
had to resize
Name:	IMG_0048 (800x600).jpg
'66 ElCamino
'68 400 Bird Ragtop
  #68
Old 12-15-2015, 07:53 PM
bobby326 bobby326 is offline
I have a 67 lemans that I just done. I was going to put on 18" wheels but the ones I want are about $1800. I have a set of REV wheel 15" torque thrusts that I just put on for now. Now I'm thinking about just keeping the 15 on but I want to put on a wider tire on the back. I has a weld wheels on with a 275/60/15 in the rear. It was a 15x8.5 with a 5.5 backs pacing cause I have a 68 12 bolt rear in it. My question is does any company make a torque thrust with that back spacing. All I see is 4.75 backs pacing or do I have to have mine cut and resized. Thanks for any info.
  #69
Old 03-20-2017, 10:09 PM
69FIREBIRD76MM's Avatar
Default torq thrust wheels
Got this for my 1969 firebird, rears 15x8.5-4.5" BS with 295-65-15 drag radials. Fronts are 15x6 with 205-70-15's. They were fully polished but I painted the spokes flat black with plastikote. Love the look.
ID:	450259   Click image for larger version
ID:	450260   Click image for larger version
The Following User Says Thank You to 69FIREBIRD76MM For This Useful Post:
  #70
Old 04-19-2017, 09:07 AM
Will the original style NEW TTs fit over my front discs? I really don't like the 'D's as much as the straight spoke. Not sure what the disc brakes on my car came off of but they are pretty standard fare. Early '70s GM probably. I'm running 15" tires and plan to keep that size.
Old 11-08-2017, 08:40 PM
Can anyone find a listing for an Original style TT in a 15x6?
Old 11-08-2017, 10:03 PM
cnc's Avatar
cnc cnc is offline
I have these legend vision series from Summit I think I got them...they are on the rear with my drag radials that's the rim only pic
I also have US mag with Street tires Firestone Firehawks hard to tell the difference when I have the drag radials on the rear and street tires on the frt....
Pic in sig is US Mags...I like the rims no issues.....
ID:	467239   Click image for larger version
ID:	467240   Click image for larger version
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
  #73
Old 11-09-2017, 03:45 PM
Those are very nice indeed.
I've already got the Torque Thrusts. I like them but the 7" width in the front is rubbing with my tires. I decided to go with 6" rims for the front but they only come in the 'D' style. Just wanted to make sure that they don't exist in the original style before I mount them.
I couldn't find them anywhere, even on the mfg.'s site.
Old 10-29-2019, 02:19 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
I got Torque Thrust II Twos last year, 15x10 with a 6" BS and 15x8 with a 4" BS for my 69. (I now have Welds with 6" BS and 295/50 fits great with lip clearance). Torque Thrusts are really cool except the 15" rears have a 13.125" drop center so most rear disc won't fit. Discount tire puts tires on wheels before test fitting, my bad for not telling them how to do their job.
I've had these for sale for a year now, took 2 months and are like $1750 now with tax I think. I'm asking way less, in for sale section.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
  #75
Old 10-29-2019, 10:34 AM
I run original torque thrusts on one of the cars here. They do make them in 5 or 6 inch, but you have to call. They aren't listed on the sites I've looked at, and I assume because when you get into the 5 and 6 inch sizes the prices literally triple over the 7" prices. You'll cringe when you find out. lol.
  #76
Old 06-07-2020, 02:01 PM
1965gp 1965gp is offline
I put the modern 20” TT on my wagon- made quite an improvement!
Always liked the vintage ones- have a few random ones in my garage.
ID:	541954   Click image for larger version
  #77
Old 06-07-2020, 02:38 PM
I can see those as a change of pace and it looks awesome...but I have to tell you, I LOVE it with the wheel discs and whitewalls. Beautiful!
Sent from my moto g(6) play using Tapatalk
Old 06-07-2020, 09:43 PM
Thanks! The white walls came with the car and are going on my 58 Bonneville when it’s painted
  #79
Old 07-27-2021, 10:34 AM
erliabol erliabol is offline
I bought my wife's old 'Stang a set of American Racing Torq Thrust rims from 4wheelonline. They looked even better in person.
