Cowl tag rivets
Did different assembly plants use different cowl tag rivets. I have 2 1969 GTO's assembled in different plants, one in Atlanta GA and one in Fremont CA. They either have different type rivets securing the cowl tag, or the plant in Atlanta filled in the rivet with dum-dum like material where the one from Fremont did not. Does anyone have a 69 GTO built in Fremont with the rivets filled in?
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
On earlier cars in is common to find that some plants did this and others did not. I wouldn't be concerned about it.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
I noticed that my 1968 Olds 442 which is also from the Fremont CA plant has the same non-filled in rivets as the 69 GTO from the Fremont plant. Not sure if the factory were the ones who attached the cowl tags, or the Fisher Body plant was. Does anyone know if the Oldsmobile and Pontiac lines were close to one another at the Fremont GM assembly plant and did any procedures carry over from one division to another?
Thanks.
Cowl tags were installed on the Fisher Body side (in the body shop, before paint). Oldsmobiles and Pontiacs in Fremont went down the same line. In the pic below of the Fremont body drop you can see an Oldsmobile, followed by a Buick, followed by a Pontiac. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Thanks Keith! That is a great picture!! I didn't realize they were one in front of the other going down the same line. So did the different divisions use the same hardware and fasteners? This picture looks, at least in this station, like it didn't matter which brand ( Olds, Pontiac, or Buick) was going down the line. Did they stay on the same line from start to finish, or did the line split into 3 lines eventually?
Yes - same fasteners and processes.
They stayed on the same line the whole way. Sometimes after the end of the assembly line, after the vehicles go through dynamic testing (roll test or brake test) they will split into separate short repair lines (but not specific to a particular nameplate/division). K
