IA2 55 mm Rear cam plug area
You guys that run or have a IA2 with a 55 mm tunnel, How thin is that area back there on yours? I was at the Machine shop Monday, and my engine guy showed me mine, obvious core shift, Wasn't very happy when i seen it to say the least. I know it's probably no big deal to most.
Mine is different.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
AG, Is your block also machined for a 55mm Camshaft?
Tom V.
No, but the material around the tunnel isn't skewed to one side like Grandville's which is what I wanted to show.
Darby, have you had the cam centerline to block/crank centerline checked?
(and I guess the lifter holes)
Measure that same side as where i measured and then Take about .138 off that what would u have left roughly, as that's half of the 55 mm size.
AP is the one that had the 55 mm tunnel bored, as my engine guy didn't have the BHJ fixture for a pontiac when i was ordering the block
Your current machine shop can measure all of that for u..
Thanks, I'm just worried how thin it is at the back, and yes i know i can have a custom plug made to fit that instead of stressing it with a frost plug there, which we're gonna do,More money out of my pocket that i shouldn't had to pay to have this plug made , let alone my engine guy check this to make sure everything is straight! It appears others aren't this bad? How much thinner are the journals on that side with that core shift? All stuff that makes me go WTF after spending this kind of money !
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's Last edited by grandville455; 04-11-2018 at 04:51 PM. |
I know its too late but I understand some guys go 50mm on the rear bearing because of this.
Are you going babbit or needle bearing ? If the final O.D. is the same you would think the roller bearing outer shell would add a little rigidity at the thin spot. It does add a fer HP too. |
It wouldn't now that your block has been bored. I know some guys went with a 50mm on the rear journal only. You can get away with it because its the last one. Need custom cam and all that. Just leaves a little more material around that thin rear area.
I think you will be fine. Maybe others who are running a 55mm will post. I hear it gets thin but it still works OK. AP has done plenty of 55mm. Since they bored it they would know if it is a issue. Sure they have seen it before. But it might have been nice if they would have picked out one that was thicker there sinece it was going 55mm. I doubt you bought the wrong block. Stand up guys. |
My MR 1 was a disaster.... my IA2 was perfect.. Darby should call and see what they will do..
Fair enough Scott no one is perfect what works for one might not work for someone else .Both are great blocks IMO..
Looks like small cracks around the oil gallery counter bore next to the cam tunnel. Should be machined/ground out so they don't travel. Barry
Thanks mark I do too! Exactly, this could become a issue down the road? I’m just gonna call frank tonight, he’s got the two pics I sent him of the tunnel , I didn’t start the thread to bash AP not my intent, I was curious if mine was worse then others, cause it’s damn thin and obviously it’s shifted during the casting process. I just want to be happy and get what I paid for and expected .
