Valley pan
Going to replace my sheet metal aftermarket valley pan with a factory unit. Which year model(s) will clear both hydraulic and solid roller lifters?
I'm not sure any of the stockers have the clearance but didn't do a ton of research. I went with a new Tomahawk pan from Butler which clears roller lifters.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5 TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
The Following 2 Users Say Thank You to Verdoro 68 For This Useful Post: | ||
My stock one from my 389 that I used ( because it was clean already ) on my 455 cleared my Comp cams solid rollers , but my non EGR one from my 400 would have worked also because I checked during mock up.
. What brand are you using in terms of lifters?
I do stuff for reasons. |
My factory 73 455 valley pan required just a bit of messaging to clear the Lunati roller lifters in the engine. That messaging made it leak a little however. I replaced it with the already mentioned Tomahawk pan which is of very good quality.
No issues w early 70s pans in the solid and hydraulic roller motors i have used factory pans on
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
The ‘73 and later EGR pans with the huge bathtub under the intake are the ones that always give you trouble.
The ‘72 and earlier pans should be good but always check for interference before buttoning it up.
The Following User Says Thank You to b-man For This Useful Post: | ||
I would say just go with a new Tomahawk pan. That way not buying a swamp meet junk that someone sandblasted inside then your motor doesn't get wiped because of it. Jeff
Carburetor building & modification services Servicing the Pontiac community over 20 years |
The Following User Says Thank You to shaker455 For This Useful Post: | ||
Thanks everyone. The Tomahawk it is, looks to be a quality piece.
I also never had a problem with 72 and earlier pans clearing, but not worth the time and effort to get them cleaned up.
Unless the build requires the later Tomahawk pan for looking correct, the early pan with the PCV in the rear is a much nicer and better fitting unit. If you look on the Butler site the 61-67 valley pan has the cutouts to clear the intake manifold ports while the later does not. It takes considerable more work getting the later pan to clear.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. |
Tomahawk pans are based on the 70 unit. I have a valley pan off a 1970 455 and it clears solid roller lifters.
For a street car the Tomahawk Valley Pan is the only choice. Clears roller lifters, looks just like the OEM unit and has factory type baffling for correct operation of the PCV system.
Tim Corcoran |
The Following User Says Thank You to Tim Corcoran For This Useful Post: | ||
Yea they do Sent from my iPhone using Tapatalk
77 T/A- poncho 400| T-10|3.23| I beams|Hyper flat top pistons|Kre heads|Scorpion rockers|Xr276 hydro roller|Rpm intake|Smi qjet|Subframe connectors|Rancho sways|Mcleod super street|hydro clutch|More i cant remember |
The Following User Says Thank You to Vroom_vroom For This Useful Post: | ||
Ouch. Can confirm that the butler tomahawk or the 68 to 70 valley pain will clear hyd roller lifters.
Motors still running if it makes you feel any better. The sheet metal one from butler replaced it. Its a nice piece one you get it fitted.
