Old 05-28-2022, 02:37 PM
ta man ta man is offline
Originally Posted by GTOLou View Post
Tend to agree - although one of my better "street" arrangements is a pusher electric pump, robbmc mechanical, cheap regulator and a cliff qjet. I put the pusher in to shorten the qjet evaporation and the long cranking.
I'll say this - I think a holley 4150 carb survives better on the street with a decent mechanical fpump than a qjet with mechanical fuel pump. Qjets starve easy, IMHO.
Running out of fuel and dropping float level happens just as quick with a larger fuel bowl Holley...a different carb is not a fix for a bad fuel supply.
  #42
Old 05-28-2022, 03:39 PM
NeighborsComplaint's Avatar
Then you have 12psi on the fuel pump dwell and 5 on the decay before the next pulse.
Triple Black 1971 GTO
