Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Windshield water stain removal
Not sure where to put this. Body maybe? Oh well. It will get seen here and people can laugh at my ineptitude.
My 50 year old windshield has some nasty hard water/acid raid stains. I’ve had some success before on a different car with white vinegar and 0000 steel wool but this windshield is having none of it. I went at it hard and those stains are just laughing at me. I just bought a cheap glass polish kit that you use with a drill. Maybe I dented it a little? But it sure as hell isnt polished. The glass is fine when you are driving in shade but man if you end up driving into the sun it’s downright dangerous. I need to fix it. Any sure fire fixes for this? I was almost wondering if CLR would work. Open to suggestions.
Did you try Bon Ami with a damp rag and rub,rub
DBANDGB |
No. I just bought some glass stove stop cleaner on a google suggestion. If that doesn’t work I’ll try a powered cleaner like that.
I’m thinking about going to buying a cheap air drill. I’m concerned about burning up my cordless.
You might try a little Lime-away bathroom cleaner. Also a clay bar can sometimes work.
1970 Trans Am RAIII 4/spd Blue/Blue Van Nuys built 1977 Can AM 400ci Sunroof car 1973 Grand Prix 400 A/T (Parting out) |
Griots garage has a Windsheild clay....and their Speedy Shine as a lube...it’s worth a shot, before you get new glass.
I have an original shield in my 64 Grand Prix.....and if it’s anthing like mine....you need a new piece of glass...I tried everything...clay bar...special glass buffing pad and spooge...
I have used RainX Xtreme Cleaner with good success.
You may have to try CLR or Lime-a-way. Make sure you wet down your paint first and rinse any overspray immediately. Work it in with a green scotch rite pad and rinse thoroughly. Are you sure the glass isn’t delaminating? |
Yep, that was what I was thinking, moisture in between the layers.
Yeah, sounds more like a foggy layer, or maybe the glass is just sandblasted. Do you see the hard water spots/deposits even in the shade or otherwise out of direct sunlight?
I went through this recently with a car that I picked up that had MASSIVE hard water deposits on all the glass. I found these special kitchen scrubbing pads at the store, then mixed up some baking soda and CLR into a thick paste, then spread it on the glass. Fill a spray bottle with CLR and gently keep the paste wet with CLR. Let it soak a bit, maybe 20-30 minutes, then scrub it off with the scrub pad. I'll post a picture of what I used tomorrow. It took a lot of scrubbing, but it did come off. |
I've never tried it but I've been hearing for decades that Coca-Cola is good for removing windshield haze and spots. Cheap to try..
Greg Reid Palmetto, Georgia |
What’s super irritating is when you rub it with glass cleaner it looks pristine for about 10 seconds until the cleaner flashes off then the haze comes back.
We had a truck at work that sat under a leaky water pipe. The stains on the glass were more rust than hard water spots. A rag soaked in Evapo-rust and left to sit on the spot for a couple hours, dissolved the stains away.
Also you can try this stuff "Spot-X" that worked well for my water spotted back window http://forums.maxperformanceinc.com/...98#post4438998 |
"And they even used Bon Ami", sorry but a quote from one of my favorite movies.
Anyway, unless youre going for a concours resto. I think I would opt for new glass. Windshields really aren't that expensive. I bought mine installed for right around $200. I have tried over the years for deep cleaning glass with little success. Nothing makes a freshly restored car look worse than bad glass, like wise fresh glass will make a mediocre car look great! |
Rock auto has the windshield by itself before shipping listed as $465 I’ll bet the glass from the early 60s GM bubble top cars are expensive too.
1967 Firebird 462 580hp/590ftlbs 1962 Pontiac Catalina Safari Swapped in Turd of an Olds 455 Owner/Creator Catfish Motorsports https://www.youtube.com/@CatfishMotorsports Last edited by RocktimusPryme; 09-20-2018 at 11:44 AM. |
That said, if it is in fact water/rust/calcium deposits, CLR and some scrubbing will take it off. It took a bunch of elbow grease on the car I was doing it on, but it did come off. |
https://www.dearbornclassics.com/win...-76-shade.html |
You know I did see that one with the green tint band. I’m not sure about that look. But that does make the replacement marginally more palatable.
