Old 04-16-2020, 10:14 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by 64speed View Post
I got the fully upgraded TKO600 and I bought a Browell tool to do bellhousing alignment because I don’t want to do the dial indicator method.
The Browell Tool is not expensive compared to many other tools and parts you need for your car. Glad you bought one. It will make getting the bellhousing right where it needs to be really easy.
Tom V.
I have known quite a few people who were held hostage by body shops over the years. They typically do not do much and then charge a bunch of money if they can't meet your time line for a finished product and you want to go elsewhere.
  #242
Old 04-16-2020, 10:47 PM
64speed's Avatar
64speed 64speed is offline
Tom it was truly awful. I mean my one armed nephew could have done better. He actually tried to tell me that he couldn’t pull the dent 6 inches from the eyebrow because he needed it on the car for leverage and to make sure the edge didn’t get too out of round for the headlight bucket
  #243
Old 04-29-2020, 02:51 PM
64speed's Avatar
Well the Trans came today. Sent out all the trim etc. to be redone today too. Just the trans came. Still waiting on the clutch and the rest of the kit. A little nervous about sending out all my trim. If something happened to it I’d be screwed. Anyway that’s where we are now.
  #244
Old 05-09-2020, 10:53 AM
64speed's Avatar
It’s going down today
  #245
Old 05-09-2020, 11:27 AM
ZeGermanHam's Avatar
Awesome! Take some photos along the way and post 'em here afterward.
1998 BMW 328is (track rat)
  #246
Old 05-09-2020, 11:32 AM
imposter's Avatar
imposter imposter is offline
did you fill the holes on the belt line trim thats what makes a tempest
  #247
Old 05-09-2020, 05:15 PM
64speed's Avatar
Already filled
  #248
Old 05-09-2020, 05:22 PM
64speed's Avatar
I just want everyone to know the TKO600 went in with no cutting other than the shifter hole. Mockup on the ground said I could run the PF24 but I can’t because of the control arm pocket so I need the shortest filter that is made if anyone can tell me. Also the Canton dipstick may not work so if anyone knows a Lokar flexible that will thread into the oil pan I would appreciate the info. Plus I need a clutch pushrod that is longer than 7 inches. Other than that I am exhausted.
ID:	539785   Click image for larger version
  #249
Old 05-09-2020, 06:20 PM
imposter's Avatar
bummer on the trim otherwise nice project hope your keeping the gold interior
  #250
Old 05-09-2020, 07:00 PM
tom s tom s is offline
OK,now go back and check everything to be sure you can get it out once the front end and everything else is in.You dont want to find out that you will have to do cutting to pull the trans if you have a flywheel boat issue.When you get the exhaust ready be sure you can get it out if you have a H or a X pipe.I had to cut mine out to get mine out.Tom
  #251
Old 05-09-2020, 07:29 PM
64speed's Avatar
I’m gonna use clamps on the X and weld everything else. I didn’t weld the tunnel porch I screwed it down so I can get to the top on at least the shifter. Everything seems to be good except the dipstick. Canton has a flexible one so I’m gonna try it.
  #252
Old 05-09-2020, 07:32 PM
Just take good measurements how far back the trans has to go to be able to drop it out.Tom
  #253
Old 05-09-2020, 07:41 PM
64speed's Avatar
Anybody got any ideas on a pushrod
  #254
Old 05-09-2020, 07:42 PM
64speed's Avatar
I don’t like the trim and the interior is gonna be the dark blue. Outside is silver.
  #255
Old 05-09-2020, 07:49 PM
Murf Murf is offline
Make one or lengthen the one you have?
Sent from my iPhone using Tapatalk Pro
  #256
Old 05-09-2020, 08:08 PM
64speed's Avatar
I don’t trust my welding ability enough to trust lengthening it and the only threaded rod I could find doesn’t look like it would hold up.
  #257
Old 05-09-2020, 08:09 PM
64speed's Avatar
I paid the upgrade fee for an aluminum driveshaft
  #258
Old 05-09-2020, 09:33 PM
1968GTO421's Avatar
At least you had great weather today to work on her. (I gor stuck cleaning up tornado damage. With all these storms, will I ever have time to finish up my Pontiac?) Glad you were able to make some really good progress today.
GTOAA--https://www.gtoaa.org/
  #259
Old 05-09-2020, 10:58 PM
64speed's Avatar
The diagram in the manual shows the clutch return spring hooked to the clutch fork and to the bracket on the exhaust manifold. For those of you running headers what are you hooking the spring too?
  #260
Old 05-13-2020, 10:59 PM
64speed's Avatar
Lost 5 HP today. Had to use a Ford 351 Windsor dipstick because it was the only one I could find that came out in the right place from the pan fitting thru the headers. The bracket was wrong so I still have to fab up one to clench it to the valve cover stud.
The Following User Says Thank You to 64speed For This Useful Post:
