New stroker pistons for 350 blocks
We worked out a deal with CP pistons on some stroker pistons for the 350 block. Here's what we have planned:
These pistons will be made from the same 2618 material as the high end custom pistons are made from. T Because of the small bore of 3.875", they will be made from the LS Chevy engine piston forgings. These are box forgings by nature and are very strong. Here are some features: 1. They will come in .030" and .060" oversize or 3.905" and 3.935". 2. They will have a .990" pin[BB Chevy] with a .150" thick wall by 2.25" long. This will be a stout pin. Even thicker .180" walled pins will be available. 3. They will have double pin oilers. 4. They will have an awesome ring package with them. 1.5 mm top, 1.5 mm second, and a 3 mm oil ring. The top ring will be a steel gas nitrite ring that will be good for N/A, nitrous, blower, or turbo applications. Second ring will be a Napier ring for the ultimate in oil control. No concern with the 3mm oil ring since it has the Napier second ring. 5. They will be a flat top design with 2 valve reliefs. A multitude of compression ratios can be made with the various Pontiac heads out there. Anywhere from 7:1-13:1 can be made. 6. They will have a CP groove on the top ring groove. This groove helps to evenly distribute the combustion pressures behind the ring when the piston rocks at TDC. 7. Very lightweight, yet very strong forging. 8. Will be built for a 6.8" long BB Chevy rod which is readily available. This will still allow for plenty of room for the rings so they are not too close to the top. 9. Made for a 4" stroke. Will make either 383 CID in .030" over, or 389 CID in .060" over. 10. Made from 2618 aluminum alloy for ultimate strength. These will sell for somewhere around $675 per set with rings and pins. This is a smoking deal. If these were customs, they would be around $1100-$1200 with rings and pins. In order to get these made at this price, we need to order at least 5 sets at a time. If anyone is interested in a set of these, contact me and let me know, and when we get 5 orders, we will get them made. They will be proprietary, so they won't be available directly from CP. Small bore/long stroke engines make good street engines because the smaller bore is less likely to detonate than a big bore, making them better for pump gas while still maintaining a compression ratio that makes good power. The long stroke will make a great torque curve. Plus, the smaller engines are better suited for the factory iron heads, so good power can be made without the expense of aluminum heads. Iron heads are very restrictive on big engines and aluminum heads are much more necessary for them . I will post a pic of one of CP's box forging for an LS Chevy engine. This will be a good representation of what these piston's underside will look like. Feel free to cal either myself or Jeff at 520-294-5758 if you have any questions.
Paul Carter Carter Cryogenics www.cartercryo.com 520-409-7236 Koerner Racing Engines You killed it, We build it! 520-294-5758 64 GTO, under re-construction, 412 CID, also under construction. 87 S-10 Pickup, 321,000 miles 99Monte Carlo, 293,000 miles 86 Bronco, 218,000 miles Last edited by gtofreek; 08-13-2013 at 11:00 PM. |
Box forgings
Here are some pics of CP's box forging.
I am more of a body/paint guy than an engine guy but I have been toying with the idea of stroking the 350 in one of my cars for additional TQ/HP rather than swapping engines (source of many debates I know). Would you explain a bit more what machining to existing crank, deck, piston wall clearance and BBC rods would be needed to use these pistons. What additional parts? I assume using the stock 350 (4") crank you get the additional C.I.'s from the longer 6.8"/special piston combo?
I understand the alternative would be a stroker crank w/special rods and standard pistons? So aside from the cost difference of stroke crank vs. stroke pistons what pros/cons would there be with stroker pistons versus crank (other than the obvious strength of these forgings). Would you still go with the stroke piston route if you wanted to add a forged crank? Thanks
1968 LeMans conv. 350 HO - 4 speed triple white (hear it idle here) https://www.youtube.com/watch?v=eVmq...ature=youtu.be 1968 LeMans conv. 350 - 4 speed Solar red/pearl |
Karl |
Ahhh. Thanks Karl. Well that makes my question moot (and plain dumb) now. I was thinking the stock stroke was 4".
A long rod 4" stroke will rev to the moon too...
Subscribing. I may choose to do a 383 for an upcoming project in the spring.... .
Karl |
Stock cast Pontiac heads are good "small block" heads vs the "big block" heads of Ford and Chevy. Good to see ya`ll started out with a piston for the 350 block vs. the others. There`s more out there now than the others. Plus, it`s a later block vs. the 326/389. |
Thanks Karl, for answering nytrainers question.
Yes, and some of those engines are 9.85:1 compression stock, with small cams too!
I like your thinking!
Now the value is gonna go up on the blocks I scrapped or gave away cheap , Seriously man, I like the sound of this build alot though. Really great for the guy with all original VIN matching 350 Firebird or LeMans Tempest etc.. to get them something torquey, 68 #17 heads on 68 350 block but the advertised 9.2"1 would go up to about 9.75 I suppose... nice
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
thanks, for taking the initiative to come out with these great new parts. the 350 has great potential and these will help realize this.
ok, where do you get a 4" stroke crank now? |
There are several places that sell them. We can sell them, as well as most any Pontiac vendor. Tomahawk Performance Products will be up and running again soon, they will have them.
Just need to get 5 sets sold so we can get started on them!
OK, now ya got my attention. What would be the build benefits of something like this (350 stroker to 4", 6.8 BBC rods)? I'm hearing great torque, rev capability, and some other stuff. I thought that the small bore/short stroke nature of the 350P was its biggest limitation? And now the stroke gets bumped out even more? What manner of witchcraft could this be?
Seriously, tho, it sounds like a kinda sexy build, but what pros/cons are we talking about? The weird factor intrigues me.
Say you have only a crappy "557" 400 block and then you have a earlier sturdy 350...mmm.. which one gets the 4" crank.... now that choice is easier
Iron heads won't be so deficient as they would be on the larger engines so a nice stout engine can be built without having to buy expensive aluminum heads. If someone wanted to put aluminum heads on, they could and it would be that much better. Larger bores are more likely to detonate. As far as cons go, I'm not really seeing any. The 6.8" rods will give a 1.7:1 rod/stroke ratio which is good. 350 blocks are in abundance[at least in my back yard ] Think how cool it would be to tell your buddy you just toasted his Chevy with a 350 Pontiac! He doesn't have to know it has a stroker crank in it.
Got the original 52,000 mile 350 from my '71 Bird. Thinking about a stroker with o-ringed block and these nice pistons with some self-induced grinding on the heads. Top it off with a Luhn performance supercharger kit with A/C. Whatcha' think?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/272@.050 Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. |
The other thing is, once Tomahawk Performance Products is back up and running completely, we would like to start working with them[since they are only a couple hours away, it makes it real easy and convenient] on bringing complete rotating assemblies to market that would truly be ready to bolt in. These kits would be fully qualified for the following:
We[Koerner Racing Engines] will balance each crank to within 1 gram or less of the assemblies bobweight. I will be doing this personally unless I'm on vacation or something[which rarely happens] in which case Jeff Koerner will do it. The big end of the rods will be checked for size, roundness, and taper/bellmouth, and trued up as needed. We hold our tolerances to .0001". The pin bushings will be honed to proper clearance[most rods come with minimal clearance and the end user usually needs to take them to a machine shop and spend money getting them honed for proper clearance]. We will figure out bearing clearances so the proper bearings will be supplied. Each bearing shell will be checked with a micrometer to verify their thickness. Also, race bearings will be furnished with cranks with large filet radius. In other words, no cheap passenger car bearings where race bearings are needed. We see a lot of kits where they supply the cheapest parts they can get whether they correct for the application or not, just so they can sell the kit cheap. Then the end user has to spend extra $'s getting the correct bearing, rings, etc., or to have the machine shop open up the clearances. Pistons will be checked for proper pin clearance. Crank will be micro polished and cleaned, as well as oil holes brushed out. Oil holes will be chamfered better if needed. Each assembly will be furnished with a spec sheet showing what everything checked out at. We don't believe in generic kits. Each kit will be Specific to itself. These will be very high quality kits at a reasonable price as well as many options for different applications.
Sounds bitchin' to me!
