Old 05-09-2023, 06:08 PM
Arrow Timing Covers for 1975 & 1976 - 1979
Timing covers in good condition, both will seal up and have minimal corrosion on the hose nipples. Please check the pictures below before purchasing. Also check your application, I’m not guaranteeing the accuracy of the P/N to which year they were used in my description.
Located in Canyon Country CA 91387
$80 each shipping included in the lower 48 states. PayPal (using friends and family), money orders and personal checks accepted. Please send me a PM if you’re interested, thanks.
Pictured below 1975 timing cover P/N 482883, I removed it from a virgin 1975 455. The darker areas on the water pump gasket surface are mostly stained and not deeply corroded, will take the most minimal smear of sealer to fill.
ID:	612331   Click image for larger version
ID:	612332   Click image for larger version
ID:	612333   Click image for larger version
ID:	612334   Click image for larger version
Old 05-09-2023, 06:14 PM
Pictured below 1976 - 1979 timing cover P/N 527292, for engines using the standard balanced not the smaller hub style. The backside near the water tube has some corrosion that won’t affect gasket seal, however you may want to add a dab of Devcon or JB Weld. Already bead blasted clean, painted and ready to bolt on otherwise.
ID:	612336   Click image for larger version
ID:	612337   Click image for larger version
ID:	612338   Click image for larger version
ID:	612339   Click image for larger version
Old 06-25-2023, 01:23 AM
Still available.
Old 02-20-2024, 04:10 PM
Still available.
Old 03-09-2024, 04:16 PM
1975 timing cover P/N 482883 is sold.
The 1976 - 1979 timing cover P/N 527292 is still available.
