Old 08-11-2008, 10:52 PM
shaggy69gradprix's Avatar
shaggy69gradprix shaggy69gradprix is offline
Default is my 455 crank done?
i got a factory cast 455 crank that is 30 on the rods & mains. the mains will polish out but the rods may need to be turned. is it possible to offset grind it to the 4.25 stroke & use the 6.800 rods? had this done in the past but the cranks were all std.dont wanna throw it out i've always had good luck with the stock cranks thanks. Shaggy
Old 08-11-2008, 11:20 PM
440GP69's Avatar
440GP69 440GP69 is offline
even if it was only ground .010 on the rods it would be tough to get to 4.25, so no at .030-.030 there is not enough meat to offset grind to 4.25 Without welding it first to add material
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 08-11-2008, 11:53 PM
screamingchief's Avatar
screamingchief screamingchief is offline
If your willing to replace stuff like rods and pistons,might wanna look into the eagle 6.635" long rods to save the crank using the 4.21" stroke.
With the eagle rods you end up going to the BBC rod journal as SOP,only catch is that rod also uses the BBC pins,so you either have to modify the existing pontiac pistons for the .990" BBC floating pins,or get some pistons that are already set-up for them.
Or I guess you could rebush the 6.635" eagles for a .980" pontiac pin,but I digress.
This space for rent...
In the meantime,check out the cars HERE.
Old 08-12-2008, 07:42 AM
Larry Navarro's Avatar
.....are we going back to pontiac power shay?
Old 08-12-2008, 11:29 AM
PONTIAC DUDE's Avatar
Thumbs up
Ditto to chief. We have sold a bunch of pistons for just that senerio. The .010 longer rod just about puts the piston at the top too.
And if the mains get beyond bearings available. Don't throw it away. I have a bearing conversion kit to put it in a 400 and all you do is turn down the mains down to 3" and also cut the seal part to 400 also.
Old 08-12-2008, 01:02 PM
J.C.you's Avatar
J.C.you J.C.you is offline
can you still get a +.040 rod bearing? used to...
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 08-12-2008, 07:29 PM
Ken -Ace- Brewer's Avatar
Ken -Ace- Brewer Ken -Ace- Brewer is offline
Send a message via Yahoo to Ken -Ace- Brewer
We carry .040 Bearings. Rods AND Mains. In stock.
Be Cool,
Ace
Am I glad I got out of the business I was in? HELL YEAH!!!
Old 08-12-2008, 09:21 PM
i will always love pontiacs.even though a ratmotor is in the frame rails now it wont be the last & final motor in the grand prix.the pontiac would walk all over this rat motor on motor but when i open that blue bottle rat wakes up! just recently came across some really nice pontiac pieces so im trying to get it put together.
