Old 08-22-2022, 05:38 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Default Trans brake..
Finally got my transmission back in and car running. I went ahead and installed a trans brake reverse pattern valve body. I have to get used to shifting in that direction..lol..but what have y'all had to do to the carb to make it leave on the brake if anything. ? I think I remember another friend telling me many years ago, that when he went to a brake he had to switch to a 30cc pump for the squirters. Any advise would get me started in the right direction. Ideally I would like the carb to work either with the brake or without.
Old 08-22-2022, 09:33 PM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
You shouldn't have to mess with the squirters. For the most consistent launches, you will use a launch control ( rev limiter) which will have the pedal floored, taking the squirters out of the equation. It took me a while to do it that way, but your 60fts and reaction times become much more managable.
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 08-23-2022, 04:53 AM
Cool, thanks. What about the suspension? Currently when leaving from a foot brake I have the suspension loaded against the axle brakes. The trans brake will have the suspension at rest. Did you need to add preload to the suspension? I'm a leaf spring car and I see from your avatar, looks like yours is coil spring.
Old 08-23-2022, 09:08 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
I have ladder bars and don't preload. Some folks tie in the line lock to help hold the car still when on the brake, but I don't see myself ever doing it since a malfunction of that magnitude can get out of hand almost instantly. I also think its against the NHRA rulebook, but Im not sure.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 08-24-2022, 09:19 AM
Mike S's Avatar
Mike S Mike S is offline
My carb is adjusted and set as if you were foot braking. No different set up for the trans brake, I tried to go smaller on the accelerator pump shot, did nothing but kill drivability.
My car loves the shock from the trans brake, Foot brake I 60' about 1.41 off the trans brake I just had a best of 1.34 Saturday. Usually averages 1,36.
Old 08-24-2022, 04:44 PM
Thumbs up
Thanks for the responses guys. I will most likely make the first few passes without the brake. It's a new motor combo and want to iron out the kinks before adding the trans brake to the tuning.
Old 08-27-2022, 01:23 PM
cgeise's Avatar
cgeise cgeise is offline
you may find you will need to do some rear shock tuning now -- depending on hp level and car weight and play with the launch rpm.
Old 08-27-2022, 09:31 PM
Good point. When I set the rear shock adjustment it was by following the recommendation of CalTrac for a foot brake car . What rpm do you guys set your 2 step at? I'm buying a 3 step.
Old 08-28-2022, 09:28 AM
Mike S's Avatar
I launch mine at 3800rpms. I notice the higher you launch the faster your reaction time is. If I start red lighting I will lower launch to to 3600 and that slows up my reaction time a tad. I launched one time at 4600 rpm and it pulled the wheels to high for comfort. Didn't like looking out the side glass to see if you are going straight
Old 08-29-2022, 08:11 AM
Start low and go up, don't do what I did after a converter change, which is to leave it set at "all of it" and forget to change it back down, then let go of the button and put it on the bumper. Holy cow.
Clutch Guys Matter
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 09-20-2022, 10:03 PM
leeklm's Avatar
leeklm leeklm is offline
I switched over to a 2 step, but still foot braking. It worked perfectly fine with zero changes to the carb, but I did ultimately change out the 50cc pump back to the oem 30cc. Figured there was no sense dumping the extra fuel into the motor when staging. I need to go through the trans this winter and may just move ahead with a trans brake as well.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
The Following User Says Thank You to leeklm For This Useful Post:
