Old 06-13-2015, 07:24 PM
jimib's Avatar
jimib jimib is offline
Default What Size is my Harmonic Balancer - Diameter (size in inches)
I need to buy timing tape (and a modern timing light) to accurately time my rebuild. The research I’ve done on harmonic balancer size is inconsistent. I have a stock (original) balancer on my engine (400). The MSD part #8985 appears to be a favorable choice on Summit. Anyone know the size? Any benefit to upgrading the balancer? This is just a street car.
1967 GTO, hard top, 400 Block, Butler Performance Build, EFI Holley Sniper, Tremec 5-Speed, Moser 373 Rear, 4 Wheel Disc Brakes
Old 06-13-2015, 08:13 PM
The 1967 and earlier balancers are 5.75" in diameter.
Do yourself a favor and replace it with a new one, any 40+ year-old balancer even if it looks great is going to fail before long.
Old 06-13-2015, 08:49 PM
jimib's Avatar
Thank you b-man. It doesn’t seem like a part that can go bad but I guess it does. The part in the picture is what I checked out on the Butler Performance web page; I bought many parts from them.
Old 06-13-2015, 08:56 PM
The rubber loses its bond after a number years is the problem. I spoke directly with the manufacturer and he said the bond is really only reliable for about 6 or 7 years.
Not exactly sure if that's true, but it's definitely food for thought.
Old 06-13-2015, 08:58 PM
jimib's Avatar
WOW, maybe this is why my rebuild (on the run stand) randomly vibrates?
Old 06-13-2015, 09:03 PM
No matter what, any new rebuild deserves a new balancer. They really almost never look worn out, but most of them are.
The one pictured above is going on my new 1964 421 HO build, everything will be new including this one part that many of us tend to overlook at rebuild time.
Old 06-13-2015, 09:12 PM
jimib's Avatar
This is my 2nd rebuild on this motor and the 2nd time I overlooked this part. Thanks for the excellent info.
Old 06-13-2015, 10:29 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Ugh..... Pretty sure mine is original also..... Looks like I am calling Butler this week also....
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 06-13-2015, 10:47 PM
Bonus: The seal will also have a new surface to ride on with the new hub supplied along with the balancer.
Old 09-05-2022, 03:24 PM
Zooguy Zooguy is offline
Just making sure i am understanding right .... My 1966 389 SHOULD have a 5.75” balancer so i would get a 5.75" timing tape for the balancer and line up the tape with the mark on it
Old 09-06-2022, 10:43 AM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
I gratefully followed b-man's excellent advice when installing my rebuilt 66 389 a couple of years ago. However, the balancer I took off, I firmly believe is 5.25" diameter. For Zooguy, at the time I could not find a timing tape offered for that diameter. The one I replaced it with (same part number from Butler) was supposed to be the same diameter (in my head).
Fort Worth/Dallas TX area
1966 GTO Fontaine Blue
389 CID Carter AFB
Muncie 4 speed (orginally an automatic car)
Old 09-06-2022, 10:57 AM
Wrap a piece of masking tape around the hub.
Measure the circumference (length of your masking tape) and divide that by 3.1416.
The hub with the timing marks on it is what you want to measure. The balancer is bolted to the hub and its larger in diameter than the hub it’s bolted to.
Old 09-06-2022, 12:47 PM
242177P's Avatar
242177P 242177P is offline
Tape? Tape?!? Dial-back timing lights don't need no steenkin' tape...
Old 09-07-2022, 07:28 PM
lust4speed's Avatar
Old post, but what the hey...
The bad news: Over the years I drag raced my '67 I had three stock balancers loose the rubber.
The good news: The cast ring is still held on because of the flared cup shape of the inner hub.
Always knew when they failed because I'd shut off the engine and the ring would continue spinning for a couple of seconds. Back then no one carried new assemblies so we'd just grab another one off a pick-a-part car -- but old is old, and they were all on their way out. Nice that new balancer assemblies are available.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
