389 in 3900# 55 Truck. Best heads, torque cam, and gear ratio?
I’ve finally found a good ‘59 389 block and crank locally that’ll bolt up to the Hydra-Matic in my 55.2 GMC 100. So I’ve resisted the urge to LS swap it so far, but man these old poncho’s are different animals completely.
I’m wanting to rebuild the engine for dependability and torque since it’s in a truck and give it more guts than the original 316. I’m also going to swap out the banjo rearend for an O/P 9.3” I’ve acquired for better choices in gearing. Other upgrades I will be adding are power brakes and a Holley Sniper or TBI retrofit at the least. Since I’m starting with just a block and crank, I’m trying to figure out what combo to build. What heads, cam, and gear ratio would be ideal for a driver that’s a fun to drive with lots of low end power and instant throttle response, BUT still able to pull a utility trailer loaded with building supplies and most importantly, dependable? The gear ratios in my hydramatic are: 4.08:1, 2.63:1, 1.55:1, and 1.00:1 if that helps. I will be running approximately a 29” tire. Those tranny gears should allow me to have a taller ratio for decent infrequent highway cruising. In terms of camshaft, I will spring for a hyd roller for durability with focus on low end and midrange power and excellent throttle response. Good vacuum and easy on valve springs. Are a must. Anybody have a good suggestions or build something similar to this back in the day? All advice is appreciated. |
Well to start with you can’t run the original heads.
I would try to turn up a set of #62 casting since with a .030” overbore your compression will be good for pump fuel. Cam wise since you want as much torque as possible you then want a cam with .450” to .470” lift. I don’t understand why you want to blow so much money on a FI set up though.
So I scored a 60k mile running 287 w/hydramatic out of a Safari for $250. I bought it for the intake and Carter 4 barrel on it. And the oil pan that has an intact unbotched drain plug.
Looks like the 4bbl intake don’t have provisions for the kickdown linkage on it. Anyway to get around this or am I screwed? I’d love to put it on the truck for the time being until I can get a 389 together. |
For the Tri-Power of my '59 I bought a generic throttle cable from some later vehicle (selected based on length I needed), built a bracket to bolt to the manifold to hold the end of the cable sheath, and a similar bracket at the HydroStick. The bracket at the carb is adjustable. It's been working fine for ten years. I could get a photo of the bracket at the carb if you want?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
What is a fair price for #62’s? Would I use the stock replacement style pistons for that 59? I’m guessing a factory flat top?
As for the sniper EFI, I know nothing about carbs. The only other carb vehicle I’ve ever had was an 86 z28 with an electric quadrajet. I I don’t have anyone left that knows the wizardry of carbs to teach me. I grew up on EFI and fair to say that I’m spoiled to it. Just get in and turn the key. For people like me, who don’t know carbs you can’t beat the dependability of a simple EFI setup. Now that port fuel injection is all the rage, I could probably find a GM TBI setup for nothing. The quadrajet sniper system is an option. I see them on marketplace for reasonable prices. I’m moving the gas tank out of the cab so I have to redo fuel lines and what not. Whichever I do, it will still have a traditional air cleaner. |
If you want torque then I would get a stroker kit with a 4.25 stroke
https://butlerperformance.com/i-2459...tegory:1234862 If your going with a hyd roller cam then I think the Lunati Voodoo 262/270 20510710 would be perfect works with a stock converter and would make great power https://www.lunatipower.com/voodoo-r...8-262-270.html. I would go with a gear ratio of 3.23 with your 29 inch tires
Tim Corcoran |
The Following User Says Thank You to Tim Corcoran For This Useful Post: | ||
I’m just trying to build what I have without butchering the truck or doing anything that can’t be easily undone to it. Otherwise I’d set it down on the c20 frame in my way and slap my L92 or 418 stroker LS and 6L90 I have laying around in it. But this ain’t really the kind of truck to do that to. |
The Following User Says Thank You to 1968GTO421 For This Useful Post: | ||
I did score a running 60k mile 287 the other day that has a 4 barrel Carter on it. I’m contemplating putting it on the 316 while I build the 389. If that Carter dies, I reckon I’ll buy one of those edelbrock carbs that are supposedly good out of the box. If it surprises me, I’m not against keeping it. But if it’s as cold natured as the Stromberg on my truck…it’ll get sold ASAP.
From what I’m reading, I’ll probably have to have this bored to use 400 pistons. Or buy custom pistons unless I want to use cast pistons. I wish they made the 4032 Forged Mahle’s for these or 400’s. I’ve got to buy rods and pistons regardless so custom isn’t out of the question. I’m thinking that would open up my choices of cylinder head availability. I have no idea of what heads were good for pontiacs. Because of rarity some are outrageous because of collector desirability. I want to avoid those. So far I’m hearing #62’s. Any other good candidates?
The only thing wrong with '59-'64 heads is it may limit your intake choice a little.
Ideally, a 1960 timing cover which would retain the front mount but use a standard cooling config would be great for 1965+ heads and pretty much your choice of intake. Any mild build would result in at least 425ft/lbs of torque. How much ya need??
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
The Following User Says Thank You to 694.1 For This Useful Post: | ||
Great to know about the timing cover!
Thanks Bill. I don't have heads yet but I’ll do 67 up heads since I have to start from scratch. I’ll probably go with a Torker intake. I find them cheap on the internet all the time. I’m going to punch it out .055 and use a 400 piston. As I understand, I can use a standard cam like the Crane hyd roller that was suggested here. Correct me if I’m wrong. The only area I’m seeing concern with this plan is with using the 1960 cover so I have the engine mount for my truck. I’ll have to drill and plumb a coolant return passage from the intake to the cover. I don’t think that should be too hard to navigate.
Make SURE that you read and understand the "interchangeability" section of Larry Gorden's page in the link below before you try to attach the '59 crankshaft to the HydraMatic's flywheel.
https://www.pontiacsafari.com/L1Gara...eID/index.html Read further down into that section and follow the link to find out why you can't put '60 or later heads on a '59 or earlier block.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. Last edited by Bill Hanlon; 02-13-2024 at 07:07 PM. |
The Following 3 Users Say Thank You to Bill Hanlon For This Useful Post: | ||
And as long as you are tearing into the '59 engine, take a look at this https://www.pontiacsafari.com/L1Gara...ealUpgrade.pdf
article I wrote about upgrading the front seal. If you decide to do it I'm still loaning out my alignment tool ($100 deposit cheerfully returned when I get the tool back, you pay the freight both ways). If you use it, you will be the 14th "customer" without a complaint yet.
The Following 2 Users Say Thank You to Bill Hanlon For This Useful Post: | ||
Thanks Bill, I’ll definitely do that Bill.
That’s solid gold info Bill. Thank you!
Thank Larry. He's the one that gathered all this early V8 info.
