Old 02-07-2023, 11:01 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default Distibutor grease?
What kind of grease is in the factory distributor under the felt washer. Can someone recommend one to use?
thanks, Dave
Old 02-07-2023, 11:58 AM
GtoFM's Avatar
GtoFM GtoFM is offline
Ditto, thx
Old 02-07-2023, 12:03 PM
Jim Moshier's Avatar
I use Dielectric Tune-Up Grease
Jim Moshier
1962 Catalina 389
Old 02-07-2023, 12:34 PM
25stevem's Avatar
25stevem 25stevem is offline
I have always used disc brake wheel Bearing grease and since a few years ago when I switched over to a synthetic type, that's what I now use.
I do stuff for reasons.
Old 02-07-2023, 12:53 PM
Kenth's Avatar
Kenth Kenth is offline
thanks, Dave
http://forums.maxperformanceinc.com/...d.php?t=652883
Name:	GM distributor well grease.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 2 Users Say Thank You to Kenth For This Useful Post:
Old 02-08-2023, 09:54 AM
dhcarguy's Avatar
TY ALL
Old 02-08-2023, 10:07 AM
I used old school wheel bearing grease, but that tube is gone. Next time i will likely have to buy a tube. Not likely going to use the stringy synth red lithium by Ford.
Old 02-08-2023, 02:20 PM
Formulas Formulas is offline
the thing with lubrication in this spot is that i believe the original GM grease was grease that would creep and move around up and out of the well when at operating temp under 200 degrees
Wheel bearing grease is designed to stay put with heat for obvious reasons and at a much higher temps
anything has to be better than nothing and the original lube is nearly unobtanium
Old 02-08-2023, 09:45 PM
Vid's Avatar
Vid Vid is offline
Haven’t used it yet but this is supposed to be ideal for the job.
