My KRE/Old Faithful 458 almost complete!
I've finally been able to get a few things to go correctly on my build and it is starting to come together! My trunk full of parts has merged into one, just have to install the oil pump, windage tray and oil pan and I will be pretty much ready to bring it down to the dyno.
I wont be able to drive it before winter but I should for sure be ready to go early next spring for some fun!! Engine specs in my sig
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
Nice goin so far,
sano lookin lighthened aluminum intake job http://forums.maxperformanceinc.com/...ons/icon14.gif beats that 50lbs cast iron intake & heat build up in engine compartment & to sumplement that intake Holley 900cfm TBI huh, thats different then most here. Oh yeah love them TH400 2.75 low gear sets.
someone who thinks logically is a nice contrast to the real world. http://www.youtube.com/watch?v=3FfKVVZW1-Y |
Sounds like fun.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Very nice!
Looks great. One question, With all of the beautiful work on the intake why did you not remove the crossover?
Who cares about the horsepower wars, Indians win the torque wars. Roger |
The main reason I wanted to cut out the crossover is I am planning on running all the wiring for the fuel injection and factory sensors/alternator wiring under the intake, and that should give me plenty of room to do so. Should clean up the installation nicely.
Please let us know how it goes on the dyno. That sounds like a real nice combo.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
458?
Yep, since its a .040 over 428 block, with a 455 crank you get a .010 over 455 which is a 458
Looks killer!
Someone can't wait till spring!
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
Well.....I got the oil pan, pulleys, alternator + bracket all bolted on as well as test fitted the headers just back from the ceramic coater.
Its starting to take shape, Not sure about the dual snorkel air cleaner yet. it kind of hides a lot of the engine which I don't really like, but Im also not a huge fan of open element air cleaners either. I may have to come to some kind of middle ground to make me happy.
Just drooled all over key board.
Jim
Thanks for all the compliments guys, I am very anxious to get this thing up and running.
I almost want to cancel the dyno and just dump it in but I really would like to see what it makes power wise first. I just have to be patient I guess...argh! I will add more progress pics as they come. Bob
Karl |
Tuning a street build engine on a engine dyno is useless waste of money, It that has to be done in the car in its own enviroment with air intake, actuall exhaust system & fuel delivery drivetrain as to be considered end user.
Yeah, I wasn't planning on doing a lot of tuning on the dyno, I was just looking to get an actual idea of what HP im making. The Holley system I have is supposed to be self tuning as I drive so that should save me some trouble.
Real nice motor/combo 428GTO70! I really like how you pre-welded the collector extensions (using the ball-socket style connectors) onto the headers prior to coating them. That will work real nice (and seal up nicely) once you bolt it into your GTO!
A quick question, what are the specs on the SD Hyd-Roller 'Old Faithful' if I may ask? Been thinking about a Hyd-Roller upgrade for my '69 Bird 406 at some point. Cheers, Brian. |
Old faithful is 236/245 @.050 on a 112 Sep. 108 icl iirc.
