Old 07-27-2021, 02:58 PM
Fast 69's Avatar
Fast 69 Fast 69 is offline
Default Wenzler Series II shaft rocker question
I purchased a used set of Wenzler heads with the shaft rockers awhile back. I believe the guy I got them from got them from KGTO at one point. I lost the bearings in an exhaust rocker and cant seem to figure out who built the system. Called Jesel and T&D and no luck. No numbers or markings on the rockers. They do have a set screw in the middle that goes thru and spaces the bearings apart. Can anyone shed some light on this setup? Thx!
Old 07-27-2021, 03:33 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Sounds like the shafts KRE was selling for a while.
Go fast, see Elvis!
Old 07-27-2021, 04:12 PM
misterp266's Avatar
Why not go to the source?
Ask Larry!
http://www.wenzlerengineering.com/PONTIAC.HTM
" Darksiders Rule "
Old 07-27-2021, 04:33 PM
Fast 69's Avatar
Thx guys. I have a call in to Larry. I will try to get ahold of KRE and see what they say.
Old 07-27-2021, 06:01 PM
Fast 69's Avatar
Larry said he only used T&D so that's no luck. Maybe KRE will shed some light on it.
Old 07-27-2021, 06:17 PM
Is there a number on any of the others? I think on my stud mount rockers you can read a bearing number in them.
Old 07-27-2021, 08:29 PM
PAUL K's Avatar
If you can post some pictures I have a box full of miscellaneous parts from those KRE shaft system. I'd be happy to see if I have what you need.
Go fast, see Elvis!
Old 07-28-2021, 07:53 AM
PAUL K's Avatar
If it is just the roller bearing you need they should be availbe from Berry Bearing they can look them up from the dimensions. If the bearings slip out of the rocker body with little or no effort the rocker body needs work or replacement. (I'm guessing that's to only way you could loose the bearing).
Go fast, see Elvis!
Old 07-28-2021, 09:08 AM
GTOGEORGE's Avatar
Ok…….I can’t let this one go……Berry Bearings……LOL!
GTO George
Old 07-28-2021, 09:11 AM
GTOGEORGE's Avatar
Please tell me that’s not his real last name……? If it is someone must not have liked him or had a hell of a sense of humor!!!
G Geo
Old 07-28-2021, 09:51 AM
Scott Stoneburg's Avatar
G Geo
Thats the company name
Old 07-28-2021, 10:06 AM
GTOGEORGE's Avatar
Yes I know……it was just funny!
GTO George
Old 07-28-2021, 10:14 AM
PAUL K's Avatar
GTO George
Then you'll like this, I believe their parent company is called Boca Bearings
Go fast, see Elvis!
Old 07-28-2021, 12:03 PM
Region Warrior's Avatar
Berry Bearing
Got lots of hard to find bearings not serviced from manufactures.
For instance
Mandrel bearings for Lawn Mower decks.
Last time bout a pair for bout $5 bucks each vs $40-$50 each for Mandrels.
Old 07-28-2021, 01:02 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
The company started out down here in Boca Raton, hence the name.
Dave Polichena
The Following User Says Thank You to Dave Polichena For This Useful Post:
Old 07-28-2021, 07:37 PM
Fast 69's Avatar
PM sent
