Air filter
Hello can't seem to find an air filter for the pancake case. I need the 14" x 1/5" filter. Have looked everywhere including Ame's. Any help appreciated.
thanks alan |
Will this work ?
https://www.knfilters.com/pontiac/gto/400-v8-carb/1967/ If not I'll bet you can find one looking thru their different sizes. https://www.knfilters.com/header-air-filters There will be skeptics here regarding a K&N filter ... listen thru the first 13 minutes https://www.youtube.com/watch?v=ow5cGV7bXCw . . .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 04-16-2022 at 03:05 PM. |
Wix also has a size locator feature. https://www.wixfilters.com/Lookup/FilterBySize.aspx
Amazon carries Wix.
Resto guide says if you've got an original pancake air cleaner assy, the suggested filter element will be stenciled on base & it should say use an AC 98C element. Attached image shows some cross interchange possibilities, I have an AC 350C in mine. Amazon carries that as well as the WIX listed, did not check any other brands
Fort Worth/Dallas TX area 1966 GTO Fontaine Blue 389 CID Carter AFB Muncie 4 speed (orginally an automatic car) |
Found out Ame's has lots of them for about 13.00 each. I swear I contacted every auto parts store, filter manufacture etc and everyone was out of them. So called Ame's to see if they knew of anyone who had them and he said yeh we do. So bought two from them.
thanks to all your help |
