Old 04-09-2018, 11:57 AM
pggto's Avatar
pggto pggto is offline
Default Wiper Arm Removal Tool
What tool are you using to remove the wiper arms? I know there are a few tools out there, but not sure which one works on that style of wiper arm. Thanks
Old 04-09-2018, 02:22 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Snap-on wiper arm adjustment tool
I bought mine from the snap-on truck years ago. It is silver zinc plated with a black vinyl handle molded over top of the steel on one end.
The one I have does not pry or need to put any pressure underneath the socket. No chance to scratch the paint.
It holds the arm in opposition of the spring tension and you can remove each arm with one hand.
Also easy to adjust the end on the fine splines to get a nice fit at the base of the windshield when parked.
Name:	Snap-on Wiper Arm removal tool.jpg
ID:	480325   Click image for larger version
Name:	Snap-on Wiper Arm removal tool~2.jpg
Peter Serio
Owner, Precision Pontiac
Old 04-09-2018, 10:54 PM
No need to see a Snap-On Stealer. Lisle Tools has them for 5 bucks..... http://sastool.com/lisle-65750-winds...m-remover.html
Old 07-03-2022, 11:24 AM
MPKind's Avatar
MPKind MPKind is offline
Works great if the locking tab is missing. Tab is easier to release if it’s on the outside of the wiper hub but some cars had the tab on the hinge side. Not easy to access with conventional tools. I can’t find anything that’ll move that locking tab.
65 Catalina 2D Post
