Old 08-18-2022, 03:11 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Default Long Journey of 1970 Firebird Restoration
My father bought the 1970 Esprit new in May of 1970 when I was 15. I was able to buy it from him in 1974 and drove it until 1998. Ohio and Michigan salt ate up a lot of the body, but I was able to find a garage stored one in Texas as the new platform for restoration. Initial prep work on the body and the chassis rebuild was done in 2000-2004, then it went into storage for 14 years again. Finally locating a suitable shop in 2018, it was into paint where the Coronado Gold was nicely duplicated. A 4.25" stroker kit from Butler was ordered for the 350 block, 6X heads were added along with Comp roller rockers, Johnson Hyd roller lifters and a Comp XR276HR cam. Len Williams did the assembly work and the engine dynoed at Reher-Morrison. After Covid delays, work is finally underway again as the serpentine kit was installed and the engine/transmission put back in the car. It will be finished out as an Esprit again with a TA hood and HD suspension package for a 1976 model including the 3.23 posi rear axle. Completion hopefully in October.
ID:	596705   Click image for larger version
ID:	596706   Click image for larger version
ID:	596707   Click image for larger version
ID:	596708   Click image for larger version
The Following 4 Users Say Thank You to srmmmm For This Useful Post:
Old 08-18-2022, 03:12 PM
srmmmm's Avatar
Next set of photos.
ID:	596710   Click image for larger version
ID:	596711   Click image for larger version
ID:	596712   Click image for larger version
ID:	596713   Click image for larger version
Old 08-18-2022, 03:13 PM
srmmmm's Avatar
Hopefully looking close to original (except for that serpentine kit, of course).
ID:	596715   Click image for larger version
Old 08-18-2022, 03:37 PM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
Nice work! That looks like it's going to be a blast to drive.
Mike
Old 08-18-2022, 03:46 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
Congrats.....I know you are excited to get it drivable again.
Love the gold color....beautiful car!
Old 08-18-2022, 04:07 PM
sdbob sdbob is offline
Congratulations, nice.
Old 08-18-2022, 04:46 PM
22687's Avatar
22687 22687 is offline
Also like the gold. Nice work.
Old 08-18-2022, 05:38 PM
Formulabruce's Avatar
Looks great!. My only comment would be that the TORKER intake is Taller than stock. There may be some aircleaner base issues, etc if you intend to have the shaker " shake" and fit correctly. Nice project! Thanks for posting!
Old 08-18-2022, 06:13 PM
Looking great!
I love the Coronado Gold!
Old 08-19-2022, 01:35 AM
srmmmm's Avatar
I ran it under the regular hood with about 3/4" clearance above the air cleaner lid. I'm hoping the TA hood has a bit more room.
Old 08-19-2022, 07:40 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Really nice looking car! What CID is it now with the 4.25" crank in a 350 and what did it do on the dyno?
Chris D
Old 08-19-2022, 08:08 AM
srmmmm's Avatar
413 cu in. 9.13 to 1 comp ratio
442 lb ft @ 4300 rpm
453 hp @ 5600 rpm
Sure, the 350 block is a small bore, but the big intake valve allows for a good cylinder fill.
The Following User Says Thank You to srmmmm For This Useful Post:
Old 08-19-2022, 08:16 AM
chuckies76ta's Avatar
chuckies76ta chuckies76ta is online now
Very nice. I run a Torker 2 on my 76 T/A. I had to mod the air cleaner a bit to make it fit. Now that you put the T/A hood on it, I'd add the wheel and trunk spoilers for a T/A look. Just me though.
Old 08-19-2022, 09:20 PM
Nice build!
Old 08-20-2022, 07:40 AM
77 TRASHCAN's Avatar
Thanks for posting! Are you in Oklahoma, Texas area?
Shut it off
Shut it off
Old 08-21-2022, 12:30 PM
OCMDGTO's Avatar
Impressive results on that engine build, pretty much doubled the original hp. Should be fun on the street
Chris D
Old 08-22-2022, 01:32 AM
srmmmm's Avatar
DFW
Old 08-22-2022, 02:03 AM
AC with manual brakes - not seen every day.
Old 08-22-2022, 09:46 AM
1968firebird455 1968firebird455 is offline
Send a message via AIM to 1968firebird455
My gold 1970 Firebird 350 is also AC with Manual brakes.
Redline Design
Old 05-05-2023, 10:43 AM
srmmmm's Avatar
It's been a wait, but we finally have the engine fully installed, plumbed, wired running in the vehicle again!
https://www.youtube.com/watch?v=nxDtH_76piU
We'll see if it moves once the new driveshaft arrives!
