Old 09-03-2021, 03:03 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Default 1974 front chin spoiler mounting diagram
I am just about finished with my 1974 T/A and have reached the point of mounting the front chin spoiler. I have looked through my assembly manual but cannot find a diagram. My car mounts the valance panel with the clips on the bottom of the radiator support. The spoiler looks like it is supposed to bolt to the radiator support close to each end. If that is the case, then those two clips are eliminated. Does someone have a diagram of how the spoiler is mounted or pics of their own car? Thanks.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 09-03-2021, 05:27 PM
Airpowr Airpowr is offline
I looked in the 75 assembly manual and it doesn’t show it either. IRC on mine 5 hex head screws attach it to the valance and rad support and the outer 2 screws attach it to the inside of the front fairings.
Old 09-03-2021, 06:46 PM
3tas4me's Avatar
Is your valance attached to the radiator support with the clips or bolts?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 09-03-2021, 06:58 PM
I know it’s all he head screws, car is in restoration shop or I’d get pics. If my memory is correct I believe the center 3 screw into U-nuts on the valance, the next outer set screws into the rad support and the outer holes have U-nuts on them and they sit inside the fairing. The clips on the support I believe are for the valance to hold it up to the support.
Old 09-03-2021, 07:06 PM
Sorry, misread you post. My valance uses all hex head screws and and coarse thread screws with washers where it attaches to the bumper. Don’t forget the v shaped spacer. I’ve never used the clips on the valance. The 74/75 valances should be the same except 75 they took the turn signals out and put in the blank off plates.
Old 09-05-2021, 06:51 PM
3tas4me's Avatar
Thanks for your reply. My valance was clipped in. Unfortunately, I didn't take the car apart so I didn't get to see how it was put together.
Still looking for a response from someone whose valance is held in with the clips.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 09-05-2021, 07:30 PM
Do you have a fiberglass valance or a stock plastic one? I’ve had 3 75 TA’s and they have all been installed using the screws. I even had to replace the rad support with a repo and it had holes for where the u clips went on.
Old 09-05-2021, 09:51 PM
3tas4me's Avatar
Mine is the original plastic valance.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 09-05-2021, 10:08 PM
Search this in the search function “1974 front lower valance help.” This thread may help you out.
Old 09-05-2021, 10:19 PM
3tas4me's Avatar
Can you post the link? I searched and only came up with this thread!
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 09-05-2021, 10:25 PM
Hope this works. https://forums.maxperformanceinc.com...84#post4715284
Old 09-05-2021, 10:31 PM
3tas4me's Avatar
I have the assembly manual and I have installed the valance with the clips as shown in that thread. The question still remains on the chin spoiler. If I bolt the spoiler to the radiator support on the two ends, where does the other two clips go? I had five clips originally and replacing two of them with bolts for the spoiler will leave two with no place to be installed?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 09-06-2021, 08:25 AM
das maler's Avatar
das maler das maler is offline
My 75’s is attached with the clip on the support. Not to say that is correct, car has been apart and painted several times in its life.
ID:	572566   Click image for larger version
Old 09-06-2021, 09:18 AM
Just want to make sure we are talking about the same thing but use different names. When you say clip are talking about the nut that clips on? That's what I call U-nut. I've attached a pic of the underside of a valance. Back 5 holes (red)are mounted to the core support and the other 5 (black) is for chin spoiler. The only thing that I'm not 100% sure of if the clip nut for the outer holes clips to the support or the the outer hole on spoiler.
Old 09-06-2021, 07:03 PM
3tas4me's Avatar
No, I am not talking about U-nuts. Pontiac came out with a clip that the back of the valance panel slides into. They were having problems with the valance panels cracking from being bolted to the radiator support. Their fix was to use clips, so the back side of the valance is not bolted to the bottom of the radiator support, it just slides into the clips which also slide onto the bottom of the radiator support in the same spot where the holes are for the U-nuts. I think that thread you posted the link to talks about the clips. Yahooskidoo made some for me as they are long discontinued from GM and nobody seems to have any. I will get a pic.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 09-06-2021, 07:37 PM
3tas4me's Avatar
Repro clip.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 10-16-2021, 07:22 AM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Here is a doc.
So long, farewell.
Old 10-16-2021, 04:43 PM
And BTW, this is how it was done prior to that bulletin.
(no removal of front section of spoiler)
Old 10-17-2021, 01:39 AM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is online now
Originally Posted by 3tas4me View Post
Repro clip.
Nice clip!
