Brake Booster and Master Cylinder help
I have a question concerning replacement of the Master Cylinder and Booster in my 74 FB. Will an NOS unit from a 78-81 Camaro work? I have no numbers on it. Another one I found is a NOS Booster for 71-74 GM brands. Stated to work on A, X and F body cars.
Would a rebuild of my master cylinder be a better option and just buy the NOS booster? My master cylinder is full of fluid but when I ride the brakes to come to a gradual stop, the pedal goes away and I have to release and pump them. This just started a week ago when I took it out for a run. Probably a good idea to replace the 40 year old parts. Any help would be great.
1972 GTO, Lucerne Blue, M22 Rockcrusher. 1974 Ram Air Formula 400,4spd,3.42 posi,honeycombs,much more.Rare Bird(sold). 2005 GTO Midnight Blue 6spd( sold). |
If the booster works why replace it? As for the master cylinder, you can rebuild yours if the bore is not pitted. Just hone it and install the replacement parts. If pitted it can be sleeved but why bother. Just replace it.
many restoration services out there
I found 1 of the rear wheel cylinders was leaking. I replaced both and bled the complete system. Going to get a couple other things done and give it a shot. I hope that was the problem. If not, then back to the booster or master cylinder. Thanks for the advice.
