How can I attach my 1/2 aluminum line to my steel braided hose. Is there a compression fitting that can be used. Please help I am stuck right now until I get this done.
Slowbird:
You need to get and AN818-8 nut and AN819-8 sleeve and flare the end of the tube with a 37 degree flaring tool(don't forget to install the nut and the sleeve first) Then get a AN815-8 union and you can attach the two together. ------------------ "Run wild with an Indian, not with the crowd in a Chevy" Check out my restoration at http://members.aol.com/jetmech15/gto
Less said,,,,,,,, Less mended. |
Thanks now the only question I have is where can I get 37 degree flaring kit. Is that just a normal flaring kit or is that a special angle. With kind of help I will have the car running in no time!
I use a regular flaring tool sold at any hardware store. It has like 5 different sizes for different pipe. Lowe's has it for $19.99. These work well on aluminun pipe but tend to wear out when used repetivley on steel such as brake lines. As far as the 37 degree flare, I know nothing about that. I do know that I've had no problems with the tool I use.
------------------ Outlaw Pontiac Racers Association "For Those Who Live The Legend" www.outlawpontiacs.com JBP 416ci on Gasoline #16 Dports 10.75:1 Compression Weight - 3300 lbs 10.5 - 29.5 TIRE Best ET: 60ft=1.39 1/8 =6.49@104mph 1/4 =10.29 @ 129mph
Outlaw Pontiac Racers Association "For Those Who Live The Legend" www.outlawpontiacs.com |
Slowbird:
You can find a 37 degree flaring tool at any aviation tool supply store. Where are you getting your AN fittings from? They should have one also. ------------------ "Run wild with an Indian, not with the crowd in a Chevy" Check out my restoration at http://members.aol.com/jetmech15/gto
slowbird,
Try Grainger or McMaster-Carr, they carry 37 degree flaring tools. There is a wide range in prices, more expensive models are designed to do stainless tubing. Good luck, Herb
74 Ventura 462/#13 heads/3350# 10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured |
