Old 03-10-2001, 01:24 AM
slowbird's Avatar
slowbird slowbird is offline
I am put a remote filter on the block and need to know which hole is the out and which hole is the in on the block. I believe the bottom is out and the top is in but I want to make sure before I hook up the lines.
slowbird's Avatar
Old 03-10-2001, 04:08 AM
WDCreech's Avatar
WDCreech WDCreech is offline
You are correct. Bottom goes to your remote filter, and the top hole goes into lube the engine.
Bill
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08
